2001 WARNING: CSV contains more number of lines than are supported by the phone template.
pendal8286
Hello all an thanks for your time and expertise.  I'm trying to validate cisco 7945 phones before inserting them into call manager and the validation continues to fail with the following message:
The phones are 7945s and the phone template I've used was copied from another import I did successfully which had two lines.  I'm confused as to the source of this error message.  The only thing I haven't done yet is create the Directory Numbers for this job and I'm wondering if that could be the problem.
Anyway, I'd appreciate you input and recommendations.  Thank you.
tunglinh174
thank for sharing. i love it.
IONIA
https://ionia.com.vn/6-cach-lua-chon-may-loc-nuoc-ion-kiem-tot-nhat
