2811 max phones
a.gooding
Level 5
Level 5
So documented is 36 phones for the 2811 CCME. what happens if you add more..say 40 max. under settings i see you can specify a max of 42.
other than a possible licensing issue will it simply reject the new phone , not register or will it simply put load on the router that will obviously have an impact on the system
paolo bevilacqua
It will accept the phone. It appears that the published maximum numbers are quite conservative.
