2901 cisco with voice card don't recognize voice commands
florent.ndombol
i bought a cisco 2901 integrated services with voice card and it seem not recognized voice commands. Did some one else have that issue ?
2 Accepted Solutions
Rajkumar Yadav
Level 4
Level 4
Hi Florent,
To make your voice command get identified by router, you need to have the uck9 permanent license.
IOS are universal and license is the one which enables the commands.
Can you paste the output for the show version command from the router.
Also you can activate evaluation license for uck9 by following the below command
here the package name would be uck9
license boot module module-name technology-package package-name
http://www.cisco.com/c/en/us/td/docs/routers/access/sw_activation/SA_on_ISR.html
Raaj
Are you going to terminate the ITSP SIP Trunk on this router( will work like CUBE).
If its like that then better have min PVDM3-16 along with uck9 license.
If you have more than 16 simultaneous call on this link then try to go for higher capacity of PVDM
Raaj
14 Replies 14
refer below doc and verify the IOS you are on is CME supported
http://www.cisco.com/c/en/us/support/unified-communications/unified-communications-manager-express/products-device-support-tables-list.html
https://supportforums.cisco.com/discussion/11080151/my-cisco-2901cme-ios-doesnt-include-telephony-service-command
do show diag / show version and verify if the voice card is properly seated/installed.
refer below doc for the reference.
http://www.cisco.com/c/en/us/support/docs/voice/call-routing-dial-plans/22377-e-doc-voice-card-recognition.html
-Venkatesh.
If you have purchased a new router with voice functionality, then, voice licenses would have come pre-loaded.
Secondly, u can also try generating evaluation uck9 licenses which would be valid for 60 days.
can u share show license feature  and show license all output from router?
regds,
aman
I Think that i don't have et uc licence. Can I activate it ?
Here is my show version command output :
Cisco IOS Software, C2900 Software (C2900-UNIVERSALK9-M), Version 15.4(3)M3, REL
EASE SOFTWARE (fc2)
Copyright (c) 1986-2015 by Cisco Systems, Inc.
Compiled Fri 05-Jun-15 13:24 by prod_rel_team
ROM: System Bootstrap, Version 15.0(1r)M16, RELEASE SOFTWARE (fc1)
gateway1 uptime is 4 minutes
System image file is "flash0:c2900-universalk9-mz.SPA.154-3.M3.bin"
Last reload type: Normal Reload
Last reload reason: power-on
A summary of U.S. laws governing Cisco cryptographic products may be found at:
export@cisco.com.
Cisco CISCO2901/K9 (revision 1.0) with 483328K/40960K bytes of memory.
Processor board ID FGL200721K0
2 Gigabit Ethernet interfaces
1 terminal line
2 Channelized (E1 or T1)/PRI ports
DRAM configuration is 64 bits wide with parity enabled.
255K bytes of non-volatile configuration memory.
255488K bytes of ATA System CompactFlash 0 (Read/Write)
License Info:
License UDI:
Device#   PID                   SN
*1        CISCO2901/K9          FGL200721K0
Technology Package License Information for Module:'c2900'
Technology    Technology-package                  Technology-package
              Current              Type           Next reboot
ipbase        ipbasek9             Permanent      ipbasek9
security      None                 None           None
uc            None                 None           None
data          None                 None           None
NtwkEss       None                 None           None
CollabPro     None                 None           None
Rajkumar Yadav
Level 4
Level 4
Hi Florent,
Raaj
florent.ndombol
Hello here the output of show version command.
EASE SOFTWARE (fc2)
export@cisco.com.
1 terminal line
License Info:
License UDI:
Device#   PID                   SN
uc            None                 None           None
data          None                 None           None
Yes, you do not have UCk9/Voice  license.
You can generate evaluation license by visiting www.cisco.com/go/license.
you can click on Get other licenses--Demo and Evaluation--Routers and Switches---ISR G2 temporary licenses ---unified communication license for 2900/300 series--Select the series for 60 days
enter Product ID which would be CISCO2901/K9  and serial number FGL200721K0
can u share show diag and show inventory as well?
regds,
aman
Thanks. Do the evaluation licenses have full fonctionality ? I guest it will work fine with my WIC card.  here is the output:
Slot 0:
        C2901 Mother board 2GE, integrated VPN and 4W Port adapter, 4 ports
        Port adapter is analyzed
        Port adapter insertion time 00:01:17 ago
        EEPROM contents at hardware discovery:
        PCB Serial Number        : FOC20044XEL
        Hardware Revision        : 1.0
        Part Number              : 73-11834-12
        Top Assy. Part Number    : 800-30795-06
        Board Revision           : H0
        Deviation Number         : 0
        Fab Version              : 03
        Product (FRU) Number     : CISCO2901/K9
        Version Identifier       : V06
        CLEI Code                : CMMJA00ARA
        Processor type           : C1
        Chassis Serial Number    : FGL200721K0
        Chassis MAC Address      : 00c8.8b9e.cdc0
        MAC Address block size   : 72
        Manufacturing Test Data  : 00 00 00 00 00 00 00 00
        EEPROM format version 4
        EEPROM contents (hex):
          0x00: 04 FF C1 8B 46 4F 43 32 30 30 34 34 58 45 4C 40
  0x10: 06 17 41 01 00 82 49 2E 3A 0C C0 46 03 20 00 78
          0x20: 4B 06 42 48 30 88 00 00 00 00 02 03 CB 8C 43 49
          0x30: 53 43 4F 32 39 30 31 2F 4B 39 89 56 30 36 20 D9
          0x40: 04 40 C1 CB C2 C6 8A 43 4D 4D 4A 41 30 30 41 52
          0x50: 41 09 C1 C2 8B 46 47 4C 32 30 30 37 32 31 4B 30
          0x60: C3 06 00 C8 8B 9E CD C0 43 00 48 C4 08 00 00 00
          0x70: 00 00 00 00 00 F3 00 65 40 01 25 41 00 87 42 00
          0x80: 00 F8 00 28 03 E8 1C 89 07 D0 20 21 0B B8 20 93
          0x90: 0F A0 21 2F 13 88 21 83 17 70 21 A8 1B 58 21 B0
          0xA0: 1F 40 21 AB 23 28 21 79 27 10 21 78 41 01 1D 42
          0xB0: 00 00 F8 00 28 03 E8 1C 20 07 D0 1F 40 0B B8 20
          0xC0: 6C 0F A0 21 34 13 88 21 34 17 70 21 98 1B 58 21
          0xD0: 98 1F 40 21 98 23 28 21 34 27 10 21 34 FF FF FF
          0xE0: FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF
          0xF0: FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF
        WIC Slot 0:
        VWIC3-2MFT-T1/E1 - 2-Port RJ-48 Multiflex Trunk - T1/E1
        Top Assy. Part Number    : 800-34658-01
        Part Number              : 73-13420-01
        Board Revision           : B0
        Fab Version              : 05
        PCB Serial Number        : FOC19494DBZ
        Version Identifier       : V01
        Product (FRU) Number     : VWIC3-2MFT-T1/E1
        CLEI Code                : COUIA7NCAA
        RMA Test History         : 00
        RMA Number               : 0-0-0-0
        RMA History              : 00
          0x00: 04 FF 40 06 EF 41 01 00 C0 46 03 20 00 87 62 01
          0x10: 82 49 34 6C 01 42 42 30 88 00 00 00 00 02 05 C1
          0x20: 8B 46 4F 43 31 39 34 39 34 44 42 5A 89 56 30 31
          0x30: 20 CB 90 56 57 49 43 33 2D 32 4D 46 54 2D 54 31
          0x40: 2F 45 31 C6 8A 43 4F 55 49 41 37 4E 43 41 41 03
          0x50: 00 81 00 00 00 00 04 00 D9 03 40 C1 CB FF FF FF
          0x60: FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF
          0x70: FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF
Embedded Service Engine 0/0 :
  Total platform memory : 524288K bytes
  Total 2nd core memory : 0K bytes
  Start of physical address for 2nd core : 0x80000000
  Virtual address start of 2nd core memory : 0x0 - 0x0
  2nd core configured disabled
  L2 cache ways for 2nd core : 0
I also do not see any PVDM3 card installed in router.
regds,
aman
I only want to use it as voice ip gateway, do i need the PVDM3 card ?
Raaj
Everything is clear now, thanks for all.
Florent
Hi Florent,
Please marked this thread as answered if you feel this answer your questions.
Raaj
YES,you need to have PVDM .
regds,
aman
Hi Florent,
I see you don't have the uck9 permanent license installed.
uc            None                 None           None
I suggest to check with your partner account and confirmed whether it is ordered.
If it was ordered, then ideally it comes pre installed.
Still you have one workaround to temporary activate the uck9 package by running below commands.
Reload would be required after entering the commands.
Try to get the permanent license if you wish to use as voice router.
Raaj
