2911 or 2811 WITH 2 AIM CUE
Hello.
I can install on a 2911 or 2811 two AIM CUE or two NM CUE or 1 AIM CUE and 1 NM CUE?
9 Replies 9
Aman Soi
Hi Eduard,
AIM-CUE  are not supported on ISR G2 series. You need to go for ISM-SRE [service ready engines ] on ISR G2 .
AIM-CUE are already end of life and replacement is AIM2-CUE
http://www.cisco.com/en/US/prod/collateral/voicesw/ps6789/ps5745/ps5520/end_of_life_C51-593700.html
Pleas refer the link for more details
http://www.cisco.com/en/US/prod/collateral/voicesw/ps6789/ps5745/ps5520/product_data_sheet0900aecd806aefe4.html
regds,
aman
Thanks for your answer Aman, but I have another question.
I can install two modules supported on the same router?
For example:
In a 2911:
  • 2 ISM-SRE or
  • 1 ISM-SRE and 1 NME
In a 2811
  • 2 AIM2 CUE or
  • 1 AIM2 CUE and 1 NME
Regards.
Hi Eduard,
Just to add to the tips from Aman (+5), Check out the following matrix:
http://www.cisco.com/en/US/prod/collateral/routers/ps10538/aag_c07_563807.pdf
IOS License for ISR G2 Support
ISR G2 Routers Supported on
IOS Version That Introduced Support
IOS Image for ISR Support
ISR Routers Supported on4
Supported Modules per Chassis
Application Modules
ISM-SRE-300-K9
IP Base
1941 - 3945
15.0(1)M
Not Supported
Maximum of 1 across the portfolio, Not supported on 3925E, 3945E
HTH,
Chris
Hi Chris.
The table is very useful.
Thaks for your response.
Hi Eduard,
Why u want to have two cards on same router?
In cisco 2811, you can install two AIMs
In cisco 2911, you can install one ISM. 2911 has no AIM slot.
regds,
aman
Hi Aman.
It is a request of the sales department.
In a company have a 2911 (with ISM) and 2811 (with AIM) and want to unify everything into one and need the maxium IVR chanels.
The NME is compatible with both?
Thanks.
Hi Eduard,
I could not find anything concrete which says on combination of two different cardsfor sam efunctionality on ISR and ISR G2 routers.
What best u can do is if you have the cards available with you , just check whether the cards are getting detected.
Above that even if it is supported  , we need to understand on the integration of combined modules.
FOr NME-CUE , u require additionally SM-NM-ADPTR on ISR G2 routers.
FOR NME-CUE, it can be inserted into 2811 NM slot.
regds,
aman
I Aman.
Thank you very much for your response.
Best regards
can i use Cisco AIM-CUE (AIM-CUE-1GBCF) Unity Expess Module with 1GB Flash Card with Cisco Router 2911 or 2951 for lab? Is this compatible?
