09-12-2014 04:56 AM - edited 03-17-2019 12:08 AM
I have 2921 cisco router with cme v8.1 and around 40 ip phones registered .
I need to upgrade cme to version 10 do I will face any problem with license after upgrade ios ?
BR
Mahmoud
Solved! Go to Solution.
09-16-2014 01:24 AM
ok Thanks aman for your great support
I will follow with cisco about this issue
09-16-2014 01:28 AM
Hi Mahmod,
Please do update once u are through with lic file.you will also get the procedure on how to upload lic files
u can aslo refer the link
http://www.cisco.com/c/en/us/products/collateral/cloud-systems-management/software-activation-on-integrated-services-routers-isr/white_paper_c11_556985.html
regds,
aman
09-19-2014 02:34 AM
Hi ,
Is your issue resolved ?
regds,
aman
09-19-2014 01:35 PM
not yet
09-20-2014 08:34 AM
if your router was sold as voice bundle so Cisco licence team will regenerate for you uc licence file.
10-16-2014 04:58 AM
After the counter has finished ,no thing happened to my license . so I think there is no problem to upgrade to the new CME and the cme license working fine till now
09-14-2014 09:05 PM
probably your uc licence was right_to_use and it worked in ios 15.1
now you have to purchase uc licence
09-13-2014 07:18 AM
probably you like me need to install 7821 phones to CME
and so you need ios 15.4 where is CME 10
you need to purchase uc licence and smartnet of course to download ios
09-12-2014 08:34 AM
there is nothing like license embedded in IOS. when u order new router with CME[bundled], it includes feature license, DSP and IOS.
regds,
aman
09-12-2014 08:06 AM
thanks for your replay
my router came with cme pre-installed license so after changing the ios to the newer one , how can the the router will know about the license as I know the license is installed within ios
