Hello all,I found that when DX650 had registered to CUCM 10.5, the Android function had disable.Did anyone know how to enable it? DX650 version 10.2.2
Hi all recently i have configured for a customer CCME , AA and FXO card but some times the FXO card start "dumming" i mean when you call the customer from outside you will be redirected to the AA and when you hand up it's fine the disconnect supervis...
I currently have a ASA 5510 with remote VPN phones authenticating via certificates. It has been working well, but now I need to change certificate vendors. I have the new certificate loaded in Callmanager, applied to the VPN profile, and installed ...
Thank you in advance for helping with this. I recently rolled out new 8831 conference phones to replace my old 7937 spider phones, unfortunately the phones are experiencing terrible incoming audio. The phones are at a branch site, connected via MPLS ...
Dear Experts.I am doing an upgrade for CUCM from version 8.6.2 to version 10.5. Due to license migration from DLU to user based licenses.to obtain the new license we need to run LCU before upgrade and send migration request to cisco licensing team.th...
I have an odd problem.I have a 7921, which registers as it should in an CUCME 8.6 environment.4 ephones, (3) 7975G and (1) 7921. One incoming / outgoing pots line. No voip. My problem:calls made from the 7921 to internal extensions work perfectly. Au...
This is not a technical question, more a commercial question. Does cisco allow resellers to multi-tenant a CUCM cluster (not HCS)?The Licencing and support would all be under the contract of the provider.Im aware of people doing this i.e. serviced b...
Hello,I have a Cisco 8831 conference phone that does not Register when powered on POE, phone displays "Phone is UnRegistered". However when I switch over to the power brick it registers just fine. So far, I've tried changing locations, perform a fa...
Is there a way to do this? This is my senario. I work for a school system we would like a way for a user to call the system and add a pre message to the district main greeting without messing with the main greeting. For instance "Today is November 5t...
I setup One Button Login as a service (it's the IP Phone Agent service but you don't have type in ID, Pwd, Ext) Works fine on 7962 but using a 7925/21 SCCP 1.3.3 and (tested with 1.3.4) I get a "Authorization Required!" at bottom of screen, then...
Hi guys We are replacing a Ericsson MD110.This PBX has a connection with a system using the E1 CAS EL7.Somebody already did the script (from/to) for E1 CAS EL7 configuration to cisco gateway e1? King Regards
Hello,Some IP phones subscribed to the service (shared phone list for remote offices). I can see service name, fast dial user ID/Pin under subscribe/unsubscribe service in phone configurationWhen I go to Device/Device settings/Phone services I do not...
Hi all, I have a unity connection and my exchange server, I have it configured to get the voice mails in my email box, but the issue is I can't sync at the moment I delete the files. E.G: If I delete the files in the Exchange I want them to be delete...
I unable to find latest Compatibility matrix for Cisco Unity Express (NME-CUE) module for integrating with CUCM 9.1.2The URL: http://www.cisco.com/c/en/us/td/docs/voice_ip_comm/unity_exp/compatibility/cuecomp.html is updated with CUCM 9.0 only.Reque...
Hi, Which Cisco IOS version supports to preserve media streaming in HSRP configuration? Do we have any Cisco supported document on the IOS version supported for Voice Thanks in advance
Subject | Author | Posted |
03-25-2025 06:06 AM | ||
03-21-2025 01:42 PM | ||
03-20-2025 05:12 AM | ||
03-19-2025 06:53 AM | ||
03-18-2025 05:41 AM |
User | Count |
5 | |
2 | |
2 | |
1 | |
1 |
