09-09-2016 05:13 AM - edited 03-18-2019 12:06 PM
Hi all,
we use some analog DECT phones on ATA190. But each call the user hears 3 beep tones (Dutdut Dutdut Dutdut). It sounds similar to some initial fax tones.
Do you know how I can avoid it?
And it occurs just in secure mode.
Solved! Go to Solution.
09-13-2016 11:35 PM
I found this bug/enhancement which you may be encountering:
"Require to remove background Beep tones in secure mode"
https://bst.cloudapps.cisco.com/bugsearch/bug/CSCva34585
The detail on the bug is pretty limited, there are no known fixed releases.
09-13-2016 09:54 PM
Hi Paul,
The 3 long tones are normal for secure calls, they indicate that the call is encrypted.
For more info on secure tones, check out the CUCM security guide here:
http://www.cisco.com/c/en/us/td/docs/voice_ip_comm/cucm/security/10_0_1/secugd/CUCM_BK_C68276B4_00_cucm-security-guide-100/CUCM_BK_C68276B4_00_cucm-security-guide-100_chapter_01000.html#CUCM_RF_SA34DE14_00
You can disable the secure tone on the ATA by unchecking the "Protected Device" tickbox under the device in CUCM.
09-13-2016 11:10 PM
Hi Jonathan,
thanks for your answer. It sounds like the correct answer, the notes at the bottom too.
But "Protected Device" is not checked :(
I did not found any enterprise phone or common phone configuration that overwrite that setting...
09-13-2016 11:30 PM
A few points:
09-13-2016 11:33 PM
1. That tickbox was never checked. It is a test device shortly installed.
2. Resetting did not helped.
3. The parameter is set to false.
09-13-2016 11:35 PM
09-13-2016 11:41 PM
Hmmm,
bugs, bugs there are everywhere bugs ;)
It is classified as "Severity:6 Enhancement" and 1.3 was not officially released... that will take a long time :(
09-13-2016 11:48 PM
Yes exactly, unfortunately if the tones are very disruptive, the device will need to be set back to an insecure mode.
***Please rate helpful responses and mark applicable answers as correct so the rest of the community can benefit.
