11-20-2015 12:06 PM - edited 03-17-2019 04:59 AM
I am trying to use the CUCM AXL API on 10.5.2. My end goal is to be able to make a query from a CCX script, but I am trying to debug the intermediate stuff before I go any further on that. The problem is when I post my query to AXL, it gives me back a 302. CURL has some options to resubmit the query which work and give me the expected output. What I am trying to determine is if there is something else I should send to AXL, or if I can POST it another way so I don't have to send it twice. Here is a transcript of what I get from CURL (sans passwords).
E:\tmp\curl_745_0_ssl>curl -k -v -u ccmadmin:PhonyPassword -H "Content-type: text/xml;" -H "SOAPAction:CUCM:DB ver=10.5" -L --post302 -d @xmldata.txt https://fon-ccx-cm01/axl
* Trying 10.236.12.23...
* Connected to fon-ccx-cm01 (10.236.12.23) port 443 (#0)
* Cipher selection: ALL:!EXPORT:!EXPORT40:!EXPORT56:!aNULL:!LOW:!RC4:@STRENGTH
* TLSv1.2 (OUT), TLS Unknown, Certificate Status (22):
* TLSv1.2 (OUT), TLS handshake, Client hello (1):
* TLSv1.2 (IN), TLS handshake, Server hello (2):
* TLSv1.2 (IN), TLS handshake, Certificate (11):
* TLSv1.2 (IN), TLS handshake, Server finished (14):
* TLSv1.2 (OUT), TLS handshake, Client key exchange (16):
* TLSv1.2 (OUT), TLS change cipher, Client hello (1):
* TLSv1.2 (OUT), TLS handshake, Finished (20):
* TLSv1.2 (IN), TLS change cipher, Client hello (1):
* TLSv1.2 (IN), TLS handshake, Finished (20):
* SSL connection using TLSv1.2 / AES256-SHA
* Server certificate:
* subject: C=US; O=Orlando Health; OU=Information Services; CN=fon-ccx-cm
01.orhs.org; ST=Florida; L=Orlando
* start date: Feb 5 21:13:34 2015 GMT
* expire date: Feb 4 21:13:33 2020 GMT
* issuer: C=US; O=Orlando Health; OU=Information Services; CN=fon-ccx-cm0
* SSL certificate verify result: self signed certificate (18), continuing
anyway.
* Server auth using Basic with user 'ccmadmin'
> POST /axl HTTP/1.1
> Host: fon-ccx-cm01
> Authorization: Basic BasicAUthString
> User-Agent: curl/7.45.0
> Accept: */*
> Content-Length: 349
* upload completely sent off: 349 out of 349 bytes
< HTTP/1.1 302 Found
< Location: https://fon-ccx-cm01/axl/
< Transfer-Encoding: chunked
< Date: Fri, 20 Nov 2015 19:39:03 GMT
< Server:
* Ignoring the response-body
* Connection #0 to host fon-ccx-cm01 left intact
* Issue another request to this URL: 'https://fon-ccx-cm01/axl/'
* Found bundle for host fon-ccx-cm01: 0x1601ef8
* Re-using existing connection! (#0) with host fon-ccx-cm01
> POST /axl/ HTTP/1.1
> Host: fon-ccx-cm01
> Accept: */*
> Content-Length: 349
< HTTP/1.1 200 OK
< Set-Cookie: JSESSIONIDSSO=375ECA70451F3BE6E811650148E02B40; Path=/; Secure; Ht
tpOnly
< Set-Cookie: JSESSIONID=EA9FEEB8B1EDF9113F0F65431906768C; Path=/axl/; Secure; H
ttpOnly
< X-Frame-Options: SAMEORIGIN
< Content-Type: text/xml;charset=UTF-8
< Content-Length: 418
< Server:
<?xml version='1.0' encoding='UTF-8'?><soapenv:Envelope xmlns:soapenv="http://sc
hemas.xmlsoap.org/soap/envelope/"><soapenv:Body><ns:executeSQLQueryResponse xmln
s:ns="http://www.cisco.com/AXL/API/10.5"><return><row><pkid>3f51b73a-b921-8af0-1
863-1b57834c85db</pkid><name>EBD</name><authorizationlevel>40</authorizationleve
l><code>27313</code></row></return></ns:executeSQLQueryResponse></soapenv:Body><
/soapenv:Envelope>* Connection #0 to host fon-ccx-cm01 left intact
07-15-2021 10:13 PM
Hello Elliot,
i know it is very late for answering after 6 years but I had the same issue recently and I spend a lot of time trying to fix it and i came through your post and i found no one replied so i think it is better to document the solution if someone else has encountered the same issue
the issue is that your are missing / in the end of the url
if you look in the url you typed in curl
and the url the server returned in 302 location header
you will see that the cucm is redirecting you to the url with / in the end
so bottom line the url should be https://cucm-ip-or-FQDN:8443/axl/ with / in the end
hope this is helpful
