CUCM 11.5 issue enabling SSO
ruudvanstrijp
Level 4
Level 4
In my lab I have recently enabld SSO for UCCX, based on ADFS running within my lab. This all works flawlessly, so I am now trying to also enable SSO on CUCM 11.5 SU2. Here I am running into an issue where running the SSO Test fails.
I can properly do the following steps:
- Verify Tomcat Certificates (Multiserver, SHA256, signed by internal CA, in the domain where the ADFS runs as well)
- Download Trust Metadata from ADFS
- Import CUCM Metadata into ADFS
However, when I try to do the SSO test, I get a popup with a certificate error. This seems to happen because the popup doesn't go to the CUCM's FQDN, but only to it's hostname (see attachment error.png). So instead of going to uc-pod5-cucm01.pod5.local (FQDN), it is only opening uc-pod5-cucm01, which of course isn't in the certificate so this fails. If I click continue anyway, I get an "Invalid Status code in Response" error from ADFS (error2.png). I assume this is because CUCM comes in via its hostname instead of FQDN.
CUCM is set up with FQDN's in System -> Server, for the Pub, Sub and IM&P server. Things like Jabber etc are working fine, so FQDN configuration doesn't seem faulty.
Any clue why I might experience this problem?
Ruud van Strijp
9 Replies 9
Cyril Albert
I have the same issue running the same version.
Did you fixe your problem?
Cyril
Run SSO Test from SAML Sign-On Confguration uses hostname instead of FQDN
CSCvc50077
Login to your ADFS server, and open PowerShell (Run as administrator). Run following command.
Get-ADFSRelyingPartyTrust –Name "XXXXXXX" | Set-ADFSRelyingPartyTrust –NotBeforeSkew 2
XXXXXXX =  Display Name of your Relying Party Trust   (for example: CUCM-Pub)
Did you get a fix for this?
Best Regards
Anyone find a fix for this on 11.5?
mattesch
Did anyone find a fix for this on 11.5?
I've exactly the same issue, does anybody figure it out a way to correct this?
Thanks!
mHadi
hi dear @ruudvanstrijp
i had this problem too, with cucm 11.5
the fix solution is >> you must browse cucm with ip address, not fqdn,
open browser, enter ip address of cucm, login, and then go to SAML-SSO menu, and do run sso test
(HTH)
(if this helps, please rate)
Mohammadreza Hadi
I am having the same issue enable SSO CUCM 12.5 with ADFS-Windows2016. Tried multiple option in setting the Claim rules and Name ID but no luck.
Anybody have solution for this issue ?    Thanks
