3750X with 10G
huntl
Dear Netpro gurus,
I have a client who needs 10GB for new 3750X.  Just curious are the following correct??  My customer wants three 3750X, with four 10GB uplinks:-
WS-C3750X-48PF-L                 Catalyst 3750X 48 Port Full PoE LAN Base                                       3
S375XVK9T-12258SE              CAT 3750X IOS UNIVERSAL WITH WEB BASE DEV MGR          3
C3KX-PWR-1100WAC/2          Catalyst 3K-X 1100W AC Secondary Power Supply                          3
C3KX-NM-10G                            Catalyst 3K-X 10G Network Module option PID                                  3
CAB-STACK-50CM                    Cisco StackWise 50CM Stacking Cable                                              3
CAB-3KX-AC-AP                        AC Power Cord for Catalyst 3K-X (Australia)                                       6
Q1a)  Are these the correct 10G modules to use for 3750X with C3KX-NM-10G??  Otherwise, which 10G modules should i use for the 10G Connections?
X2-10GB-SR                10GBASE-SR X2 Module
Q1b) I saw some which just has the following:
SFP-10G-SR=             10GBASE-SR SFP Module
Q1c) Do i even need to have the C3KX-NM-10G module at all??
Q2)  Can the X2-10GB-SR be used by WS-C4948E-E?
Cheers,
Hunt
acampbell
Hunt,
Look at this link
http://www.cisco.com/en/US/prod/collateral/switches/ps5718/ps6406/data_sheet_c78-584733.html
C3KX-NM-10G
this is the carrier module for the GBICs
The C3KX-NM-10G has 4 ports but depending on your GBIC selection
you may not use all of them. Look at table 4 in the link.
You will also need to order the GBICs but you will
need to know
which type of media you will be using
E.g.
Single mode fibre
Multimode fibre etc
Again look at table 19
SFP+Transceivers for Cisco Catalyst 3750-X and 3560-X Series
SFP-10G-LR=
10GBASE-LR SFP+ module
SFP-10G-SR=
10GBASE-SR SFP+ module
SFP-10G-LRM=
10GBASE-LRM SFP+ module
SFP-H10GB-CU1M=
10GBASE-CX1 SFP module
SFP-H10GB-CU3M=
10GBASE-CX3 SFP module
SFP-H10GB-CU5M=
10GBASE-CX5 SFP module
Alex
Regards, Alex. Please rate useful posts.
Leo Laohoo
When you say 10Gb, are you talking about copper or fibre?
C3KX-NM-10G will have two 10Gb SFP+ and C3KX-NM-10GT have two 10Gb copper ports.
Hi Leo,
My client is thinking of 10Gb fibre.
But do i need to even order the C3KX-NM-10G?
Can i just have purchase the SFP-10G-SR=??
Cheers,
Hunt
The 3750X does not include the C3KX-NM-10G.  This is an option you need to purchase.  So yes, you need to order the
C3KX-NM-10G or the 3750X will arrive at your client's location without one.  You will also need to order the SFP+ module of your choice.
