3845 FXO Does Not Register
dtom
We just installed a PDVDM-32 and a VIC2-4FXO card into a 3845 router (2).  The FXO ports in one of the 3845 routers is registered and works fine.  However, in the second 3845 router, the FXO ports show as unknown.  The "sh ccm" command shows that the router is registered to CM.
Any thoughts here as to what we can do?
Jaime Valencia
Start by comparing the configurations and make sure there is no typo, or something configured with the wrong values.
java
if this helps, please rate
We checked the configuration and it looks like it is fine.  However, the "show-ccm" command shows:
Configuration Auto-Download Information
 No configurations downloaded
Current state: Downloading XML file
Configuration Download statistics:
        Download Attempted             : 4
          Download Successful          : 3
          Download Failed              : 0
          TFTP Download Failed         : 1
        Configuration Attempted        : 2
          Configuration Successful     : 0
          Configuration Failed(Parsing): 0
          Configuration Failed(config) : 2
Last config download command:
FAX mode: disable
Configuration Error History:
voice-port 0/0/0
 signal loopStart
end
What can we do here?
