SPIAD cisco 2901
tfsnchez88
 Hi all.
I need help with how configuring voice mail and AA in my cisco spiad.
If some one have one manual or any configuration for that.
I can see other configuration about CME, and  I don´t know if the configuration for cisco spiad is the same.
I hope the community help me with my configuration.
thanks for all and best regards.
I want to convert a 2901 that's in my lab to a SPAID, being that the software comes bundled is there another iOS just for SPIAD?
Hi.
I don't have vm, because spiad have all services. but thanks for you answer.
Hi Eddie.
This router 2901 support this features, you only need have a ISM module, the name spiad, its just that name, but really is a router with support for telephony service.
If you have this router, you can check your ISM module.
#router$ show inventory.
then you could find a current ios for this router.
and ready. you will use this like a spiad.
