3905 in CME provisioning
clark white
Level 2
Level 2
Dears
In my network 3905 phones are not registering they are stuck in provisioning, attached are the logs and running configuration.
try setting the expiration under voice service voip.... I'm running out of ideas
registrar server expires max 1200 min 300
8 Replies 8
Tagir Temirgaliyev
conf t
voice register global
  create profile
exi
wr
Dear Tagir,
I did the above before many times but still they are not registering.
thanks
Experts
Anybody can help me to get success.
thanks
Have you tried to remove the phones and then re-add them then do a create profile?  A reboot might be of help too.
Dear Brandon
Here is the attached ,i removed the phones and then re-add,  i reload after creating a profile, even though the phones are not registering,
when i entered a command create profile it gave me the below error though the files are present int the flash:/its/
"%Error deleting flash:/its/SEPBC671CDD0BD7.cnf.xml (File not found)
%Error deleting flash:/its/SEPBC671CDCD355.cnf.xml (File not found)
thanks
hey hey
thanks Brandon +5 for you
have a look below
  MWI unsolicited notify is disabled
  Active registrations  : 2
  Total SIP phones registered: 2
  Total Registration Statistics
    Registration requests  : 2
    Registration success   : 2
    Registration failed    : 0
    unRegister requests    : 0
    unRegister success     : 0
    unRegister failed      : 0
    Attempts to register
           after last unregister : 0
    Last register request time   :
    Last unregister request time :
    Register success time        :
    Unregister success time      :
hi team ,
i have a issues in my cisco ip phone (CP-3905) is stuck in provisining.
