11-22-2014 09:07 PM - edited 03-17-2019 01:03 AM
Dears
In my network 3905 phones are not registering they are stuck in provisioning, attached are the logs and running configuration.
Solved! Go to Solution.
11-24-2014 11:32 AM
try setting the expiration under voice service voip.... I'm running out of ideas
registrar server expires max 1200 min 300
11-23-2014 06:29 AM
conf t voice register global create profile
exi
wr
11-23-2014 12:13 PM
Dear Tagir,
I did the above before many times but still they are not registering.
thanks
11-24-2014 07:01 AM
Experts
Anybody can help me to get success.
thanks
11-24-2014 09:38 AM
Have you tried to remove the phones and then re-add them then do a create profile? A reboot might be of help too.
11-24-2014 10:44 AM
Dear Brandon
Here is the attached ,i removed the phones and then re-add, i reload after creating a profile, even though the phones are not registering,
when i entered a command create profile it gave me the below error though the files are present int the flash:/its/
"%Error deleting flash:/its/SEPBC671CDD0BD7.cnf.xml (File not found)
%Error deleting flash:/its/SEPBC671CDCD355.cnf.xml (File not found)
thanks
11-24-2014 11:32 AM
11-24-2014 12:24 PM
hey hey
thanks Brandon +5 for you
have a look below
MWI unsolicited notify is disabled
Active registrations : 2
Total SIP phones registered: 2
Total Registration Statistics
Registration requests : 2
Registration success : 2
Registration failed : 0
unRegister requests : 0
unRegister success : 0
unRegister failed : 0
Attempts to register
after last unregister : 0
Last register request time :
Last unregister request time :
Register success time :
Unregister success time :
07-02-2020 01:31 AM
