3905 registration issue with 3COM switch
Cisco IP Phone 3905 is not getting voice lan information from 3com switch.The phone is not registering.
11 Replies 11
Gordon Ross
Level 9
Level 9
Use the command
# lldp admin-status rx
on each port you have a 3905 plugged into.
GTG
Please rate all helpful posts.
Gordon,
 After the add the cmd also its not taking voice vlan.
Please see the interface level cmds. I configured.
interfac gib 1/0/19
port link-type trunk
 port trunk permit vlan 1 220 240
 port trunk pvid vlan 220
 undo voice vlan mode auto
 voice vlan 240 enable
 broadcast-suppression pps 3000
 undo jumboframe enable
 poe enable
 stp edged-port enable
Gordon Ross
Gordon Ross
Our suggested 3Com configuration is:
Global level
# lldp enable
At port level
# port link-type hybrid
# port hybrid vlan 9999 tagged
# lldp voice-vlan 9999
GTG
we configured with as you mentioned.But still it is not getting voice vlan.
Voice vlan 240
Data vlan 220
Please see the below configuration on interface level:
interface GigabitEthernet1/0/46
 port hybrid vlan 240 tagged
 port hybrid vlan 1 220 untagged
 poe enable
Please let me know if any change needed.
You appear to be missing the command:
# lldp voice-vlan 240
From the port config.
GTG
3COM switch not allowing to config below cmd.
#lldp voice-vlan 240
lldp voice-vlan 240
Any thing we need to do on core switch level. Core switch is also 3COM switch. But except 3905 phone, all other models of phones are working fine.
It's nothing to do with your core switch: It's just some funny interaction between your edge switch and the phone. Here's another way to try configuring the 3Com edge switch:
Global level:
# lldp compliance cdp
Port level:
# voice vlan 240 enable
GTG
Already we tried with the above cmds. but no result
In which case I'm out. Those are the two methods we use here to get 3Com switches to support the 3905 phones.
Sorry.
GTG
interface GigabitEthernet1/0/19
 poe enable
lld compliance cd is enabled on global
