Failed Calls within a Dial-Peer?
drbabbers
Level 3
Level 3
All,
Can someone please explain the meaning of these values in bold within a VoIP dial-peer:
Successful Calls = 1156, Failed Calls = 14244, Incomplete Calls = 3
I am slightly worried that I have 14244 calls showing as failed.
*This is a Cisco UBE on the end of a SIP Trunk to an ITSP and this dial-peer is the incoming dial-peer which matches the DDI range and sends the digits to CUCM.
Dean
Aaron Harrison
It means 14244 calls have failed - this could be for any reason; e.g. config issues when this was implemented, a transitory failure at some point in the past...or they might be calls that are currently failing.
I would be checking to see if it is incrementing.
If it is you can trace the calls (debug ccsip messages) to see what is going wrong.
Aaron
Aaron Please remember to rate helpful posts to identify useful responses, and mark 'Answered' if appropriate!
