3945 Router using E1 Qsig integrations with Mitel 3300
julio.vergara
I am configuring in Cisco Router 3945 with E1 Qsig to contact a MITEL 3300
This is the configuration:
isdn switch-type primary-qsig
controller E1 0/1/1
 framing NO-CRC4
 clock source internal
 line-termination 75-ohm
 pri-group timeslots 1-31 service mgcp
 description Mitel
interface Serial0/1/1:15
 no ip address
 encapsulation hdlc
 isdn overlap-receiving
 isdn incoming-voice voice
 isdn bind-l3 ccm-manager
 no cdp enable
voice-port 0/1/1:15
 echo-cancel coverage 64
 cptone MX
 timeouts call-disconnect 0
 timeouts wait-release 1
 description  QSIG - Mitel
dial-peer voice 503 pots
 incoming called-number .
 direct-inward-dial
 port 0/1/1:15
when i connect the E1, the E1 up but i can not receive calls and make calls.
This configutation is correct for connect to E1?
acampbell
Hi Julio,
Can you try making the Cisco end of the link network mode.
One end should be user and the other network
Usually PBXs will default as "user" as the PSTN/SP-Nets are
always "Network". So one end needs to act as the NETWORK side
in order to allow the operate.
MITEL (USER) ------------------(NETWORK) Cisco
On your CUCM admin pages set the mgcp end point
"Protocol Side " field to Network
Update and reset
On the router config
shut
isdn protocol-emulate network
no shut
no mgcp
mgcp
Retest calls
Hope this helps
Alex
Please rate useful posts
Regards, Alex. Please rate useful posts.
Hi ,
In addiiton to what Alex has said, can u try running the debug voip ccapi inout and debug isdn q931?
regds,
aman
islam.kamal
Level 10
Level 10
Can you share " show isdn status" & "debug isdn q931"?. We need to make sure that layer 1 and layer 2 are up. Other question can you share your design ?. We need to know after the call come it will transfer to IP phone using MGCP & H323 or you solution CME based.
please rate all useful information
julio.vergara
This is the configuration and this works
controller E1 0/0/0
 framing NO-CRC4
 description ***MITEL***
interface Serial0/0/0:15
 no ip address
 encapsulation hdlc
 no cdp enable
voice-port 0/0/0:15
 input gain -6
 output attenuation -6
 cptone MX
 description QSIG PBX Mitel
 direct-inward-dial
 port 0/0/0:15
 forward-digits 4
tomorrow send the configuration in the CUCM.
regards
