07-17-2007 10:40 AM - edited 03-14-2019 10:37 PM
i have an uprgade to 4.3 for CCM, i am wondering if somebody did it before or he can guide me thgrough.
i mean does it need to uprgade the OS first or the CCM first.
Good day
Solved! Go to Solution.
07-18-2007 11:44 AM
take a look at step 11 under "Upgrading Related Cisco CallManager Services and Detecting the Server (Required)"
Basically the system is restoring the DB from your BARS backup tar file.
Chris
07-17-2007 10:50 AM
You do the OS install first and then use BARS to restore the DB.
This link should help you:
HTH,
Chris
07-18-2007 10:59 AM
thanks a lot for the info, very helpful.
are you sure i need to restore the DB.
as the document is saying just upgrade, it is not mentionning a restore once i have upgraded the OS.
any way i have only one server in the cluster, so it should not be tuff ;-)
Good day
07-18-2007 11:44 AM
Chris
11-03-2007 03:42 AM
Do I have to complete entire upgrade inclusive of the subscribers in a single exercise?
Coz right now I have a situation where after finishing with the Publisher upgrade, I cannot see the CCM users page.
The subscriber is still at 4.1(3), my third party apps are failing as a result of being unable to access the user information.
How do we proceed?
