10-21-2011 12:03 PM - edited 03-16-2019 07:39 AM
We've seen some noise issues on calls on our CUCM.
We have 3 PRI/T1 with our service provide Paetec. And 2 PRI and 1 T1 set up between our Rolm 9751 and CUCM.
All PRI/T1 have high numbers of Total Rx RPT lost pkts (over 4 billions each) when looking at device status. Occasionally I can catch a Total Rx RPT lost pkts on specific ports when looking at the PORT status, but mostly these run clean. As usage increases on a PRI, the rate of lost pkts increases too.
1. Is there a way to clear the device Total RX RPT lost pkts counts?
2. Is there a correlation between the Device Total RX RPT lost pkts and the noisy calls we're hearing?
3. Where do I look to resolve this.
I do not see errors on the Rolm 9751 side of the PRI's.
Thank you.
Frank Kirstein
10-23-2011 05:14 PM
Frank,
6608 getting old now.
Your problem is probably due to poor "CLOCKIN" configuration,
Hopefully your ROLM 9751 is attached somewhere to the PSTN/ISDN network and sould be deriving its clock from the there.
So if you select your PSTN links to clock from "NETWORK" then clock the ROLM links from "SPAN 1 to 8" so that they are synched with the PSTN links , basically all clocks should be locked as one.
Hopefully this will stop your received errors
Alex
10-24-2011 06:07 AM
Thank you Alex. I'll change the clocking source and see what I end up with.
12-06-2011 05:39 AM
Hi Alex,
It took awhile, but I now have all the PRIs set to 1 clock source. Paetec to our Rolm 9751 T1 to Span 7 on the 6608. All the PRI on the CCM from Paetec and internally get the clock from Span 7. Traffic looked clean for about 2 hours, than 1 Lost Pkt followed by 246 lost packets, and finally, 4 billion. I actually caught a Port status which shows port 22 with RTP Sent Pkts of 318, RTP Rcvd pkts of 318 and Lost RX pkts of 4294901760. All of our PRI/T1 show lost pkts of over 4 billion.
Any ideas?
Thanks all.
