09-01-2012 08:25 AM - edited 03-16-2019 12:58 PM
I am trying to setup 6901 phone with call manager 8.6.
The problem is that these phones do not take ip address at all and going thru the data sheet i found that these phones do not support vlans.
In our setup we are using 2960 switches and there are multiple vlans and also voice and data vlans are seperate therefore i removed the data vlan from the swithc port and just kept the voice vlan and still it does not take any ip address.
When i am bringing the switch port to data vlan it take the ip of data vlan but i want it to obtain the ip address of voice vlan.
If anyone faced this problem before please share.
Solved! Go to Solution.
09-01-2012 09:30 AM
Hi Malik,
I think you may be seeing this bug;
Description
Details
Status:
Fixed
Last Modified:
Aug 15,2012
Product:
Cisco Unified IP Phone 6900 Series
Platform:
Dependent
Severity:
3 - moderate
Cheers!
Rob
"Every fool's got a reason to feelin' sorry for himself" - Springsteen
09-01-2012 09:28 AM
Update phone fimrware.
09-01-2012 09:30 AM
Hi Malik,
Description
Details
Status:
Fixed
Last Modified:
Aug 15,2012
Product:
Platform:
Dependent
Severity:
3 - moderate
Cheers!
Rob
09-01-2012 12:18 PM
I am not sure where you read that 6901 doestn support vlan but believe it is totaly wrong. These phones support vlans as all phones
Can you post you switch config?
Please check that your voice vlan is created on all switches between the switch that the phone is connected and the switch that the dhcp server is connected. Also check your trunk ports. I believe that there is someting wrong on your switch config and not on the phones
Hope it helps.
09-01-2012 01:43 PM
Well i solved the problem taking a hint from the rob.huffman's post though theres some workaround written but its not clear.
We had vlan 10 as data and vlan 50 as voice.
Therefore i change the switch configuration to following:
interface Fastethernet 0/1
switchport mode access
switchport access vlan 50
and whoao it took the dhcp and registered with CUCM and i was like pulling my hair for this really simple configuration.
@smartns04: Well i do not say anything without proof and when i am saying i read in the cisco document one should respect whats being said.
FYI: copied from cisco doc- Note Cisco Unified IP Phone 6901 does not support VLANs.
can be found on the following link: http://www.cisco.com/en/US/docs/voice_ip_comm/cuipph/6901_6911/8_0/english/admin/guide/6911ins.html
Thanks for the support rob and paolo.
09-01-2012 05:25 PM
Glad you solved the problem,
Dont get offende i was just trying to help. I have a setup with around 500 6901 that work perfectly on the voice vlan. it is a hotel and we used them as bathroom phones . i have a detailed look on the posts you send me but my works fine.
Cheers
09-01-2012 11:12 PM
They use poor choice wording. What the writer meant, is that VLAN are not supported for devices connected to the PC port, that is, thart cannot carry tagged frames. Of course the phone (when running fixed firmware), supports data VLAN, and a single, tagged voice VLAN.
09-03-2012 08:38 AM
@smartns04: sorry bro,its my bad i acted really rude.
@Paolo: i could not get " device connected to pc port" as 6901 phones do not have a switch like legacy phones to connect to PC.
