6921 Wall Mount - The Clip to keep the phone on hook keeps falling out!!
steigja
Level 3
Level 3
Has anyone experienced this issue with the 6921 on-hook clips.  We turn the clip around when the phone is wall mounted and it hold the phone in.  But it comes out so easily, as soon as you lift the handset out it pulls the clips out!!! we have like 30 - 6921 phones that have done this.  I need to know if its possible to get spare 6921 clips, because we need them, anyone have an info on this?  Thanks
7 Replies 7
jj2212
Did you find a vendor for these parts? I'm in need of them too.
were you able to find? we have the same issue. students seem to take them off.
no, All the vendors I talked with say the phone is too new and not worth the money to fabricate yet. Not enough call for them.
we are going to try and glue them in
we will try 3D print them and then glue.
some of ours are missing
Hello Fellas, we where unsuccessfull in getting these clips.  I think we are also opting to glue them in.
Laurel McDargh
We have a couple hundred of the 6921 model. I have searched high and low. Wall phones are critical for us, so when the clip goes, we have to replace the entire phone--not very economical.
I have resorted to gluing them--learned my lesson the hard way.
