06-10-2008 11:55 AM - edited 03-15-2019 11:11 AM
Locally, we have 7 digit dialing in the 214 area code. There are also surrounding areas in an 830 area code that have an option to have a âmetro" line that allows 10 digit dialing without tolls. I need to be able to dial 7 digits locally, 10 digits to the 830 area code and 1 + dialing to the 830 area code. Can someone send me commands to accomplish this?
06-10-2008 03:03 PM
Glad we can help....dont forget to rate posts that you found helpful.
06-19-2008 11:26 AM
I am on site now, I am doing something wrong. I set up the trunk-group fxo, if I do a sh trunk-group fxo all of the ports display. So, I added:
dial-peer voice 100
destination-pattern 9[2-9]......
incoming called-number.
trunk-group fxo
forward-digits 7
cntl-c
dial-peer voice 200
destination-pattern 91830.......
trunk-group fxo
forward-digits 11
cntl-c
dial-peer voice 300
destination-patern 9830.......
incoming called number.
trunk-group fxo
forward-digits 10
Nothing has changed. I still cannot make 10 digit calls to the 830 area code.
06-19-2008 11:43 AM
I assume the command spelling errors are not in the config ?
What do you get when calling 9830xxxxxxx ?
06-19-2008 11:54 AM
Yes, the spelling errors were in my communication to you, not on the cofig.
As I press 98305551212 the phone starts to dial at 98305551
06-19-2008 11:59 AM
Right. Configure:
dial-peer voice 100
preference 2
dial-peer voice 300
no huntstop
Now if you could finally tell us which exchanges are to be called 7 or 10 digits, a configuration can made so that users can use either all the time :)
06-19-2008 12:12 PM
The exchange is 830. It does not need to dial 7 digits though. It needs to be able to dial 10 digits if it is a "metro" line or 11 (1+) if it is not.
06-19-2008 12:16 PM
Hi, 830 is actually the area code.
The following three digits are called the exchange ID, but do not necessarily map to a single exchange. Knowing them will discriminate a "metro" line or not.
In other words, an exchange-based configuration would let you call either 9 + 10 or 91 + 10 to al area code 830. I medioned 7 digits by mistake before.
06-19-2008 12:51 PM
Got it. I thought I had explained what I was needing incorrectly.
Is the exchange id the same as the prefix? (830-XXX-xxxx) This area code surounds San Antonio and would have dozens of them.
06-19-2008 01:06 PM
You explained perfectly from the first post, it was me having an hard time explaining myself, anyway telco do these things, as I understand that if you call with 1 an exchance that can be called without, you're billed more just because the confusion they made ?
The XXX in your example above is also properly called "exchange prefix" or NXX. With the proper configuration is possible to collapse many under a same DP. You have to look at the list of the "metro" exchanges, I must believe is officially published somewhere.
06-19-2008 01:37 PM
This is a list of the most popular ones. It will take me a while to come up with all of them. 303, 985, 816. 426, 510, 379, 372, 537, 401, 665
Thanks.
06-19-2008 02:34 PM
With these you can only optimize as
37[29]
All the others will need a separate DP. You can also check the exchanges that are not "metro", if easier to patterning.
Do calls work now with the preference config ?
