IP Telephony and Phones
Labels
Hello, We are currently using a Be6000 system and when we schedule a call forwarding on our phones (model 7945) to external numbers, it works perfectly when the original call comes from an internal position, but when it is an external call then this ...
Translator by Community Manager
  • 6050 Views
  • 14 replies
dial-peer voice 200voip preference 1 destination-pattern 7… progress_ind setup enable 3 voice-class codec 1 voice-class h323 1 session target ipv4:10.12.0.2 dtmf-relay h245-alphanumeric ip qos dscp cs3 signaling no vaddial-peer voice 201voip pref...
Hi,Can anyone help i have configured a skinny vg224, and on my voice gateway i keep getting an ephone registering un-registering. The device shows in the vg224 as a AutoCfg_Virtual_Endpoint Oper State: ACTIVE - Cause Code: NONEActive Call Manager: 10...
Hi,I've a problem with hookflash on my VGs.I have a 4.2sr3 CCM custer.I have been installed the VG224 ( 12.4.T5 ) on my network.I have perceived that when I press the flash key on my analog phones, nothing happens. I still earing the person on the li...
rdamaso by Level 1
  • 545 Views
  • 2 replies
Hi, I have a Call Manager 6.0.1 and configured at the beginning 3 IP phones. They are registered and have the real phone numbers. Calls to outside und within the network are fine, but calls from outside are rejected (number unknown). I see on the gat...
ezy by Level 1
  • 911 Views
  • 2 replies
