7821-CME
Toss Leey
In case I don't have any file for 7821 in CME, can I use fast-track method without download any files for 7821in ISR flash?
Thank you
Yes, you can. See a example below:
New phone model
Recommended Fast-track config
7821
voice register pool-type  7821
xml-config maxNumCalls 6
xml-config busyTrigger 6
xml-config custom sshAccess 0
num-lines 2
description Cisco IP Phone 7821
reference-pooltype 6921
7841
voice register pool-type  7841
num-lines 4
description Cisco IP Phone 7841
reference-pooltype 6941
7861
voice register pool-type  7861
num-lines 16
description Cisco IP Phone 7861
reference-pooltype 6961
__________________________________________________
Please remember to rate useful posts clicking on the stars below.
LinkedIn Profile: do.linkedin.com/in/leosalcie
I tried and works fine +5(:
Read this will help you.
http://x-ccie.blogspot.ae/2014/12/cisco-cme-fast-track-feature.html
Akshay Sachdeva
Hi Faziz,
If your 7821 IP phone has a firmware/software install on it then you do not need any extra files. You can configure the 7821 in CME using fast start method and would be able to use your IP phone.
Akshay
