08-18-2015 10:10 AM - edited 03-17-2019 04:02 AM
We have 7962 & 7821 phones to add into CME 10.0
7962 phones registered successfully where I am not able to register 7821 SIP.
Phone screen showing " Registering "
Phone got IP Address from DHCP server.
From attachments, 7821 phone is getting correct load but not sure why its not registering:
7821 phone shows Active Server as None
please check the attachments
Following is my configuration
ip dhcp pool BMD-voice
network 10.40.34.0 255.255.255.0
option 150 ip 10.40.34.7
default-router 10.40.34.7
voice service voip
allow-connections h323 to sip
allow-connections sip to h323
allow-connections sip to sip
supplementary-service h450.12
redirect ip2ip
fax protocol t38 version 0 ls-redundancy 0 hs-redundancy 0 fallback none
h323
sip
bind control source-interface GigabitEthernet0/0
bind media source-interface GigabitEthernet0/0
registrar server expires max 3600 min 1800
voice register pool-type 7821
xml-config maxNumCalls 2
xml-config busyTrigger 2
phoneload-support
num-lines 2
description ***Cisco IP Phone 7821 Ref to 6921***
reference-pooltype 6921
voice register global
mode cme
source-address 10.40.34.7 port 5060
max-dn 500
max-pool 265
load 7821 sip78xx.10-1-1SR1-4
authenticate register
authenticate realm all
timezone 31
date-format D/M/Y
tftp-path flash:
create profile sync 0015832366215588
voice register dn 6
number 123
name ABCD
label ABCD
voice register pool 6
busy-trigger-per-button 1
id mac afcd.2Dca.1489
type 7821
number 1 dn 68
dtmf-relay rtp-nte
no call-waiting
codec g711alaw
no vad
tftp-server flash:kern78xx.10-1-1SR1-4.sbn
tftp-server flash:rootfs78xx.10-1-1SR1-4.sbn
tftp-server flash:sboot78xx.10-1-1SR1-4.sbn
tftp-server flash:sip78xx.10-1-1SR1-4.loads
CME#dir flash:
Directory of flash0:/
1 -rw- 96347284 Nov 19 2014 16:19:08 +03:00 c3900-universalk9-mz.SPA.153-3.M3.bin
2 -rw- 3064 Nov 19 2014 16:31:44 +03:00 cpconfig-39xx.cfg
3 drw- 0 Aug 12 2015 07:46:40 +03:00 its
4 drw- 0 Nov 19 2014 16:32:16 +03:00 ccpexp
245 -rw- 2464 Nov 19 2014 16:34:00 +03:00 home.shtml
252 -rw- 3088960 Aug 18 2015 13:28:40 +03:00 kern78xx.10-1-1SR1-4.sbn
253 -rw- 36176212 Aug 18 2015 13:29:50 +03:00 rootfs78xx.10-1-1SR1-4.sbn
254 -rw- 347580 Aug 18 2015 13:30:08 +03:00 sboot78xx.10-1-1SR1-4.sbn
255 -rw- 1007 Aug 18 2015 13:30:28 +03:00 sip78xx.10-1-1SR1-4.loads
261218304 bytes total (122355712 bytes free)
CME#
CME#show version
Cisco IOS Software, C3900 Software (C3900-UNIVERSALK9-M), Version 15.3(3)M3, RELEASE SOFTWARE (fc1)
Copyright (c) 1986-2014 by Cisco Systems, Inc.
Compiled Wed 28-May-14 07:13 by prod_rel_team
ROM: System Bootstrap, Version 15.0(1r)M16, RELEASE SOFTWARE (fc1)
BMD-CME uptime is 4 hours, 1 minute
System image file is "flash0:c3900-universalk9-mz.SPA.153-3.M3.bin"
Last reload type: Normal Reload
Last reload reason: power-on
Solved! Go to Solution.
08-18-2015 11:03 PM
Hi ilana,
The reason for failure is the fact that you are enabling SIP digest authentication under voice register global using the command ' authenticate register & authenticate realm all'. While the phone isn't configured for username/password under voice register pool.
I am sure if you enable debug ccsip mess, you will see 401 response all the time.
I believe your phone and CME are in the same LAN therefore, digests authentication isn't mandatory and you can disable it be removing the commands ' authenticate register & authenticate realm all'. Else, you need to configure username/password under voice register pool.
Also, as Vivek mentioned, looks to be a mistake in mapping DN to the phone. But I don't think this should impact registration. This will allow the phone to register without DN.
08-18-2015 10:25 AM
Can you please reset t he phone and collect below debugs
1) debug tftp events
2) debug tftp packets
2) debug ccsip messages
Br,
nadeem
08-18-2015 01:26 PM
Hi Nadeem,
I will be able to share debug outputs by tomorrow.
Thank for your reply.
08-24-2015 02:32 AM
Hello all,
Continuing the above post, two of 7821 phones are not registering to CME.
Switch port is in voice vlan, phone is getting TFTP server ip address but not sure why its not registering. Following are the output of debug tftp packet and debug tftp event from CME:
Phones that are not registering are having following mac-address:
84802DD451E1
84802DD451E3
CME#
Aug 24 09:17:33.881: TFTP: Server request for port 51788, socket_id 0x1125A264 for process 433
Aug 24 09:17:33.881: TFTP: read request from host 10.40.34.86(51788) via GigabitEthernet0/0
Aug 24 09:17:33.881: TFTP: Looking for CTLSEP84802DD451E1.tlv
Aug 24 09:17:33.881: TFTP: Sending error 1 No such file
Aug 24 09:17:34.041: TFTP: Server request for port 51088, socket_id 0x1956A7FC for process 433
Aug 24 09:17:34.041: TFTP: read request from host 10.40.34.86(51088) via GigabitEthernet0/0
Aug 24 09:17:34.041: TFTP: Looking for ITLSEP84802DD451E1.tlv
Aug 24 09:17:34.041: TFTP: Sending error 1 No such file
Aug 24 09:17:34.249: TFTP: Server request for port 50023, socket_id 0x1125A264 for process 433
Aug 24 09:17:34.249: TFTP: read request from host 10.40.34.86(50023) via GigabitEthernet0/0
Aug 24 09:17:34.249: TFTP: Looking for SEP84802DD451E1.cnf.xml
Aug 24 09:17:34.249: TFTP: Sending error 1 No such file
Aug 24 09:17:34.505: TFTP: Server request for port 52697, socket_id 0x1956A7FC for process 433
Aug 24 09:17:34.505: TFTP: read request from host 10.40.34.86(52697) via GigabitEthernet0/0
Aug 24 09:17:34.505: TFTP: Looking for XMLDefault.cnf.xml
Aug 24 09:17:34.505: TFTP: Opened system:/its/vrf1/XMLDefault.cnf.xml, fd 4, size 3450 for process 433
Aug 24 09:17:34.505: TFTP: Sending block 1 (retry 0), len 512, socket_id 0x1956A7FC
Aug 24 09:17:34.509: TFTP: Received ACK for block 1, socket_id 0x1956A7FC
Aug 24 09:17:34.509: TFTP: Sending block 2 (retry 0), len 512, socket_id 0x1956A7FC
Aug 24 09:17:34.509: TFTP: Received ACK for block 2, socket_id 0x1956A7FC
Aug 24 09:17:34.509: TFTP: Sending block 3 (retry 0), len 512, socket_id 0x1956A7FC
Aug 24 09:17:34.509: TFTP: Received ACK for block 3, socket_id 0x1956A7FC
Aug 24 09:17:34.509: TFTP: Sending block 4 (retry 0), len 512, socket_id 0x1956A7FC
Aug 24 09:17:34.509: TFTP: Received ACK for block 4, socket_id 0x1956A7FC
Aug 24 09:17:34.509: TFTP: Sending block 5 (retry 0), len 512, socket_id 0x1956A7FC
Aug 24 09:17:34.509: TFTP: Received ACK for block 5, socket_id 0x1956A7FC
Aug 24 09:17:34.509: TFTP: Sending block 6 (retry 0), len 512, socket_id 0x1956A7FC
Aug 24 09:17:34.513: TFTP: Received ACK for block 6, socket_id 0x1956A7FC
Aug 24 09:17:34.513: TFTP: Sending block 7 (retry 0), len 378, socket_id 0x1956A7FC
Aug 24 09:17:34.513: TFTP: Received ACK for block 7, socket_id 0x1956A7FC
Aug 24 09:17:34.513: TFTP: Finished system:/its/vrf1/XMLDefault.cnf.xml, time 00:00:00 for process 433
Aug 24 09:18:04.322: TFTP: Server request for port 51112, socket_id 0x12C6C758 for process 433
Aug 24 09:18:04.322: TFTP: read request from host 10.40.34.141(51112) via GigabitEthernet0/0
Aug 24 09:18:04.322: TFTP: Looking for CTLSEP84802DD451E3.tlv
Aug 24 09:18:04.322: TFTP: Sending error 1 No such file
Aug 24 09:18:04.486: TFTP: Server request for port 50292, socket_id 0x1125A264 for process 433
Aug 24 09:18:04.486: TFTP: read request from host 10.40.34.141(50292) via GigabitEthernet0/0
Aug 24 09:18:04.486: TFTP: Looking for ITLSEP84802DD451E3.tlv
Aug 24 09:18:04.486: TFTP: Sending error 1 No such file
Aug 24 09:18:04.730: TFTP: Server request for port 50927, socket_id 0x12C6C758 for process 433
Aug 24 09:18:04.730: TFTP: read request from host 10.40.34.141(50927) via GigabitEthernet0/0
Aug 24 09:18:04.730: TFTP: Looking for SEP84802DD451E3.cnf.xml
Aug 24 09:18:04.730: TFTP: Sending error 1 No such file
Aug 24 09:18:05.010: TFTP: Server request for port 52519, socket_id 0x1125A264 for process 433
Aug 24 09:18:05.014: TFTP: read request from host 10.40.34.141(52519) via GigabitEthernet0/0
Aug 24 09:18:05.014: TFTP: Looking for XMLDefault.cnf.xml
Aug 24 09:18:05.014: TFTP: Opened system:/its/vrf1/XMLDefault.cnf.xml, fd 4, size 3450 for process 433
Aug 24 09:18:05.014: TFTP: Sending block 1 (retry 0), len 512, socket_id 0x1125A264
Aug 24 09:18:05.014: TFTP: Received ACK for block 1, socket_id 0x1125A264
Aug 24 09:18:05.014: TFTP: Sending block 2 (retry 0), len 512, socket_id 0x1125A264
Aug 24 09:18:05.014: TFTP: Received ACK for block 2, socket_id 0x1125A264
Aug 24 09:18:05.014: TFTP: Sending block 3 (retry 0), len 512, socket_id 0x1125A264
Aug 24 09:18:05.014: TFTP: Received ACK for block 3, socket_id 0x1125A264
Aug 24 09:18:05.014: TFTP: Sending block 4 (retry 0), len 512, socket_id 0x1125A264
Aug 24 09:18:05.014: TFTP: Received ACK for block 4, socket_id 0x1125A264
Aug 24 09:18:05.014: TFTP: Sending block 5 (retry 0), len 512, socket_id 0x1125A264
Aug 24 09:18:05.014: TFTP: Received ACK for block 5, socket_id 0x1125A264
Aug 24 09:18:05.018: TFTP: Sending block 6 (retry 0), len 512, socket_id 0x1125A264
Aug 24 09:18:05.018: TFTP: Received ACK for block 6, socket_id 0x1125A264
Aug 24 09:18:05.018: TFTP: Sending block 7 (retry 0), len 378, socket_id 0x1125A264
Aug 24 09:18:05.018: TFTP: Received ACK for block 7, socket_id 0x1125A264
Aug 24 09:18:05.018: TFTP: Finished system:/its/vrf1/XMLDefault.cnf.xml, time 00:00:00 for process 433
Aug 24 09:18:06.026: TFTP: Server request for port 51489, socket_id 0x14165444 for process 433
Aug 24 09:18:06.026: TFTP: read request from host 10.40.34.86(51489) via GigabitEthernet0/0
Aug 24 09:18:06.026: TFTP: Looking for CTLSEP84802DD451E1.tlv
Aug 24 09:18:06.026: TFTP: Sending error 1 No such file
Aug 24 09:18:06.182: TFTP: Server request for port 49256, socket_id 0x12C6C758 for process 433
Aug 24 09:18:06.182: TFTP: read request from host 10.40.34.86(49256) via GigabitEthernet0/0
Aug 24 09:18:06.182: TFTP: Looking for ITLSEP84802DD451E1.tlv
Aug 24 09:18:06.182: TFTP: Sending error 1 No such file
Aug 24 09:18:06.390: TFTP: Server request for port 51362, socket_id 0x14165444 for process 433
Aug 24 09:18:06.390: TFTP: read request from host 10.40.34.86(51362) via GigabitEthernet0/0
Aug 24 09:18:06.390: TFTP: Looking for SEP84802DD451E1.cnf.xml
Aug 24 09:18:06.390: TFTP: Sending error 1 No such file
Aug 24 09:18:06.646: TFTP: Server request for port 52635, socket_id 0x12C6C758 for process 433
Aug 24 09:18:06.646: TFTP: read request from host 10.40.34.86(52635) via GigabitEthernet0/0
Aug 24 09:18:06.646: TFTP: Looking for XMLDefault.cnf.xml
Aug 24 09:18:06.646: TFTP: Opened system:/its/vrf1/XMLDefault.cnf.xml, fd 4, size 3450 for process 433
Aug 24 09:18:06.646: TFTP: Sending block 1 (retry 0), len 512, socket_id 0x12C6C758
Aug 24 09:18:06.646: TFTP: Received ACK for block 1, socket_id 0x12C6C758
Aug 24 09:18:06.646: TFTP: Sending block 2 (retry 0), len 512, socket_id 0x12C6C758
Aug 24 09:18:06.646: TFTP: Received ACK for block 2, socket_id 0x12C6C758
Aug 24 09:18:06.646: TFTP: Sending block 3 (retry 0), len 512, socket_id 0x12C6C758
Aug 24 09:18:06.646: TFTP: Received ACK for block 3, socket_id 0x12C6C758
Aug 24 09:18:06.646: TFTP: Sending block 4 (retry 0), len 512, socket_id 0x12C6C758
Aug 24 09:18:06.650: TFTP: Received ACK for block 4, socket_id 0x12C6C758
Aug 24 09:18:06.650: TFTP: Sending block 5 (retry 0), len 512, socket_id 0x12C6C758
Aug 24 09:18:06.650: TFTP: Received ACK for block 5, socket_id 0x12C6C758
Aug 24 09:18:06.650: TFTP: Sending block 6 (retry 0), len 512, socket_id 0x12C6C758
Aug 24 09:18:06.650: TFTP: Received ACK for block 6, socket_id 0x12C6C758
Aug 24 09:18:06.650: TFTP: Sending block 7 (retry 0), len 378, socket_id 0x12C6C758
Aug 24 09:18:06.650: TFTP: Received ACK for block 7, socket_id 0x12C6C758
Aug 24 09:18:06.650: TFTP: Finished system:/its/vrf1/XMLDefault.cnf.xml, time 00:00:00 for process 433
Aug 24 09:18:09.654: TFTP: Server request for port 50855, socket_id 0x14165444 for process 433
Aug 24 09:18:09.654: TFTP: read request from host 10.40.34.141(50855) via GigabitEthernet0/0
Aug 24 09:18:09.654: TFTP: Looking for SEP84802DD451E3.cnf.xml
Aug 24 09:18:09.654: TFTP: Sending error 1 No such file
Aug 24 09:18:09.918: TFTP: Server request for port 52692, socket_id 0x12C6C758 for process 433
Aug 24 09:18:09.918: TFTP: read request from host 10.40.34.141(52692) via GigabitEthernet0/0
Aug 24 09:18:09.918: TFTP: Looking for XMLDefault.cnf.xml
Aug 24 09:18:09.918: TFTP: Opened system:/its/vrf1/XMLDefault.cnf.xml, fd 4, size 3450 for process 433
Aug 24 09:18:09.918: TFTP: Sending block 1 (retry 0), len 512, socket_id 0x12C6C758
Aug 24 09:18:09.922: TFTP: Received ACK for block 1, socket_id 0x12C6C758
Aug 24 09:18:09.922: TFTP: Sending block 2 (retry 0), len 512, socket_id 0x12C6C758
Aug 24 09:18:09.922: TFTP: Received ACK for block 2, socket_id 0x12C6C758
Aug 24 09:18:09.922: TFTP: Sending block 3 (retry 0), len 512, socket_id 0x12C6C758
Aug 24 09:18:09.922: TFTP: Received ACK for block 3, socket_id 0x12C6C758
Aug 24 09:18:09.922: TFTP: Sending block 4 (retry 0), len 512, socket_id 0x12C6C758
Aug 24 09:18:09.922: TFTP: Received ACK for block 4, socket_id 0x12C6C758
Aug 24 09:18:09.922: TFTP: Sending block 5 (retry 0), len 512, socket_id 0x12C6C758
Aug 24 09:18:09.922: TFTP: Received ACK for block 5, socket_id 0x12C6C758
Aug 24 09:18:09.922: TFTP: Sending block 6 (retry 0), len 512, socket_id 0x12C6C758
Aug 24 09:18:09.922: TFTP: Received ACK for block 6, socket_id 0x12C6C758
Aug 24 09:18:09.922: TFTP: Sending block 7 (retry 0), len 378, socket_id 0x12C6C758
Aug 24 09:18:09.926: TFTP: Received ACK for block 7, socket_id 0x12C6C758
Aug 24 09:18:09.926: TFTP: Finished system:/its/vrf1/XMLDefault.cnf.xml, time 00:00:00 for process 433
BMD-CME#
BMD-CME#
08-24-2015 02:49 AM
Please share debug ccsip mess.
08-24-2015 12:02 PM
Hello Mohammed,
Issue solved.
Actually these two mac addresses were added new. I read in some document saying that you should run create profile if newly added SIP phones are not registering.
I did same and both phone registered immediately.
Thanks for your time to reply.
08-19-2015 07:32 AM
Hi Nadeem,
As i mentioned above, my issue fixed by removing authenticate register from voice register global.
As issue resolved I didn't need to collect logs.
Appreciated your time to reply here.
08-18-2015 09:11 PM
Please check if it's a type error under voice register pool 6;
number 1 dn 68
However DN index defined in voice register dn is 6 (voice register dn 6).
08-18-2015 11:03 PM
Hi ilana,
08-18-2015 11:45 PM
Hi Mohammed, +5. Seems digest authentication issue as well.
Apart I believe that without DN, SIP phone won't be able to register as DN must be included in respective header of REGISTER message and without DN, phone won't be able to trigger REGISTER message and can't register. That is the reason we see multiple REGISTER requests if SIP phone is assigned multiple DN.
This might be different from SCCP registration behavior where phone doesn't use DN to register and hence can register even without DN assignment.
Vivek
08-19-2015 01:29 AM
Good point Vivek. I think you are right. What I said is applicable to SCCP not SIP endpoints.
11-15-2018 11:13 PM
Hi Vivek,
I had below problems in 7841 IP phone some phone have differnet load ID and some have diffent thats the diffence that In phone there is line in display phone the app load ID is rootfs78xx.10-1-1SR1-4.bin
08-19-2015 07:29 AM
Hello Mohammad,
Thank you so much for such a confident answer.
Your advise worked. No Authenticate register fixed my issue
Thank you every body who helped here.
