7821 through expressway
arashad
Hi All ,
I tried to register 7821 through expressway but it gave me "not found" although the jabber registered successfuly.
R0g22
78XX need to be at a minimum 11.0.1 firmware for MRA. What is the firmware that you are running ? Also what is the cucm and expressway version ? Is the phone prompted for a MRA
login ?
This version already active .
Jaime Valencia
Was the EXP-E certificate signed by one of the public CAs which are required for MRA with ip phones?
java
if this helps, please rate
Hi Jaime,
The problem solved by reinstalling the certificate but i have a new problem we have a third part corporate directory and it appears when using jabber by MRA and not appear when using the hard phone when using MRA !!!!!!!!
