phone and fax
elite2010
Level 3
Level 3
If I want to use phone and fax for the same DID,How is that possible ?
For example if it is for voice need to send to call manager and if it for fax need to send stonefax server from the voice gateway
It's not so easy but you can use a special vxml script able to detect fax and transfer a call.
You can get more information at this link:
https://www.cisco.com/c/en/us/td/docs/ios-xml/ios/voice/cube_proto/configuration/15-mt/cube-proto-15-mt-book/voi-cube-fax-detection-vxml.pdf
Regards.
