01-18-2008 03:30 AM - edited 03-15-2019 08:18 AM
I have little problem with my 7921G phones.
When somebody calls you, and you press "red button" to reject a call, that call is not actually rejectet, but instead the phone goes to "silent" state. In other states this button works perfect.
I have CCME 4.1 on 124-15T IOS, Phone load ver. 1.0.4.
Any answers will be higly appreciated!
Solved! Go to Solution.
01-18-2008 04:34 AM
Thank you for the nice rating and come back with any questions you may have!
01-18-2008 03:34 AM
As far as I know, none of the cisco phones has a button to reject the call.
The only thing that can be done when the phone is ringing, is to silent the ring, using "DND" softkey on fixed terminals, red button on the wireless.
01-18-2008 03:40 AM
Thx! Could you give me a link to some .doc, where i, probably, can find additional information?
01-18-2008 03:49 AM
There is no document about 'rejecting calls', because there is no such feature.
If you look in the "ccme system administrator guide", the function fo the DND softkey is explained.
01-18-2008 03:57 AM
So SCCP control protocol doesn't have such type of message, to instruct CCM, that call should be rejected, and only available feature - DND. Am i right?
01-18-2008 04:16 AM
Yes, as mentioned above, it is not possible reject calls from cisco phones under CCME.
As a recognition to those providing answers, please rate useful posts using the scrollbox below!
01-18-2008 04:31 AM
Many Thx! I really appreciate your help!
01-18-2008 04:34 AM
