IP Telephony and Phones
Labels
Hi There !I'm having a problem with CCM 4.2 MoH .. but when I try to use it, the other phone just listen a 'bip bip bip' not the music... It was working sometime ago.. but I can't say what I did to make it stop...I tryied to change the DevicePool, an...
Hi Guys, I need some help if anyone can, my company wants to re-route our mobile numbers through another company so pro-ceding each mobile number dialed from within the company they want to add for instance a four digit number "1624" does any one kno...
Hello all. I have a couple of questions Id like to ask. Im wondering first, is there a good IPCC upgrade guide? and two, is there a list of all cisco call center versions and their names at the time? It seems like they change the name of what I kn...
Hi Pro.i have a CME router.the number we are receiving in directory without 00 in front and the user cannot dial from directory.i have to create translation rule incoming,so that it changes all the incoming international number with 00 in front.thxx
The docs make it look too easy: 'utils ntp config' seems like it should change the NTP references, but all it does is give me the following status:"This node is configured to synchronize with its hardware clock".Is there any way to set the server up ...
HiDoes AIM-VOICE-30 in 3725 WIC slot support? I will not use any NM or EVM, just the integrate WIC slots2 qty VIC-2BRI-S/T-TEand1 qty VIC-4FXS/DIDThe following links mention general support but not btwn all threehttp://www.cisco.com/en/US/prod/collat...
aamercado by Level 4
  • 331 Views
  • 2 replies
