07-21-2015 12:18 PM - edited 03-17-2019 03:43 AM
I am working on a CUCM cluster that was recently upgraded to 9.1.1.20000-5 and since the upgrade the corporate directory on the 7925 phones is not working. The user just gets and error of not found. We have tried performing a factory reset on the 7925 phones but that didn't make any difference. Also all the other phones work perfectly fine. I've attached the logs from one of the 7925 phones for review. Any suggestions would be greatly appreciated.
Michael
07-21-2015 12:30 PM
Which version did you upgrade from? You may need to check your "Enterprise Service Parameter" and very the non-secure URLs (e.g. http://X.X.X.X:8080/ccmcip/xmldirectory.jsp)
Yosh
07-21-2015 12:46 PM
Agree with yosh , just the URL if its set to secure port then 7925 would fall into this situations as this phones does not support secure port .
Br,
Nadeem Ahmed
07-21-2015 09:35 PM
From the logs I can see that you are running secured cluster. Looks that your root certificate has changed after the upgrade and getting certificate error to connect on SSL to CUCM.
As suggested by the guys below. Disable https for time being to get corp dir working. This will even work on the working phones.
But I suggest to look at the security problem within your cluster to avoid problems.
