02-04-2008 12:50 PM - edited 03-15-2019 08:36 AM
Hi there,
Quick question, we just got a 7937 conference phone. When we dial a specific number we have the call go through a Sip trunk to a sip device. When the call connects, the call does not pass dtmf to the connected device.
All the other phones in our network seem to pass dtmf over this trunk properly, except the new phone. I have updated the phone to version 1.1 of the firmware
I am also runnning CM 5.1.1
02-06-2008 08:52 PM
I have the same problem but with a 7971G.
I'm running CM5.1.3
Thks
05-23-2008 11:50 AM
I am having the same isssue. Has anyone resloved this?
05-23-2008 12:50 PM
What type of DTMF do you have in the dial-peer that is handling the call?
10-03-2008 02:11 AM
There is a known defect about it in 1.0(2). This defect is fixed in
1.2(1) like "CSCsm04556 - 7937 sends wrong DTMF digits when pressing * and #" and "CSCso31642 - 7937 IP phone does not transmit RFC 2833 on a sip trunk with 5.X CUCM".
You can double check the firmware file from the callmanager interface : Device > Device Settings > Device Defaults, look for the 7937, and if 1.0(1), you should see "apps37sccp.1-0-1-0" in front of the 7937 (that is the standard version with 6.1.1 or earlier).
so probably you need an upgrade.
