06-08-2011 12:34 PM - edited 03-16-2019 05:21 AM
i starting to build a lab with CUCM 8 and a 2008 SRV with DNS, DHCP,AD,.....
now if i start the phone with a factory reset, the right ip is set from the dhcp and the right options.....
it loads the phone load and then restart the phone and try to open the call manager (
"Opening <ip from call manager>") and thats it.... this goes in a loop.....
What could be the problem?
Any ideas?
Jason
06-09-2011 03:07 AM
Maybe CCM service is not running?
JH
06-09-2011 04:49 AM
Have you looked into any routing issues or something blocking SCCP?
java
If this helps, please rate
www.cisco.com/go/pdihelpdesk
