01-09-2017 07:32 AM - edited 03-17-2019 09:07 AM
Hi All,
I have a customer on CUCM v7.1.3 (out of support from Cisco). They wanted an external user to be added to their corporate directory so I manually added an End User to the system.
If I search for the user in the Corporate Directory using CIPC I can find him, however when the customer tries the same using his 7941 phone he cannot see him in the results.
Has anyone come across this before?
Many thanks
Solved! Go to Solution.
01-09-2017 11:22 AM
Are the phone and CIPC using different directory URLs? Is the URL configured properly in enterprise parameters? Do you have a different URL configured at the device level in CUCM?
01-09-2017 08:40 AM
Couple of things:
1. Have you tried resetting the phone?
2. Do you have more than one CUCM server? Are both the CIPC client and the 7941 registered to the same server? If not, and one works and the other does not, this could indicated a database replication problem. The following link shows steps to check and repair the replication.
Brandon
01-09-2017 09:36 AM
Hi Brandon,
Thanks for your reply. I had already tried a reset on the phone and have also restarted the TFTP services on both servers. I registered the CIPC to the same server as the phone and I still had more entries when searching for the name 'John'. I have noticed that the Directories URL on my CIPC phone is pointing to a URL that does not include the IP addresses of the CUCM servers.
01-09-2017 11:22 AM
01-24-2017 06:32 AM
It would appear that after checking the URL for the directory they were pointing to some AD server, not the CM server for contacts. Advised them to add the entry there.
Phil
