ā04-20-2016 07:18 AM - edited ā03-17-2019 06:39 AM
HI, i have a 7942 phone that appears to not accept my reset commands. I'm holding down # when it boots, then the line lights flash i release and do the 123456789*0#. The screen will go to the Cisco logo even as i'm typing in the sequence, then go the Upgrading screen with firmware that i'm pretty sure is on my call manager/TFTP. It never completes then boots the phone. In the Settings menu I'm unable to unlock the phone using the **# sequence. This was a phone setup with Phone proxy, now that it's back on my network i need to factory reset as it's got public IP CM info and an Alternate TFTP. I can't unlock that setting. Anyone ever heard of this before? I tried taking it apart and the piece behind the buttons seems to be intact. If it's fixable anyone have a good source for repairs? I believe it's out of warranty. No smartnet.
Thanks.
robyn
ā04-20-2016 09:48 AM
Robyn,
Try this :-
Alex
ā04-20-2016 09:51 AM
Thanks i have tried that, but it's like it doesn't accept that i'm pressing the # sign. Because the line buttons flash once then it goes straight to the Cisco screen. Then an upgrading screen and it boots up with the same configuration. Unlocking any settings after it boots doesn't work with **#.
ā04-21-2016 11:45 AM
Try this:
Go to settings menu, press **# -this should unlock the menu--go to ipv4-alternate tftp-disable it or type in the right tftp.save
and then try the factory reset procedure again.
ā04-21-2016 02:00 PM
Also tried that, the **# isn't being accepted to unlock any settings.
ā09-13-2022 10:24 AM
I have the same issue. It's like the phone recognized the # key...the line buttons will alternately flash as long as I hold it down, but as soon as I release it (or even try to enter the number sequence while holding it down ) I get the cisco splash screen and it tries to boot...no upgrading at all. HELP!@!
