7942G stays registering...and no dial tone
Tero Kaira
I have CME 8.6 and one 7942G at the same LAN called LAN A.
Another 7942G phone is at different LAN, called LAN B.
CME shows that both SIP phones has been registered and router can see both mac addresses. Both phones can get their numbers from CME.
Ping is 100% ok from CME to the phones.
The problem is:
when I try to call from LAN A 7942G -> to LAN B 7942G, the phone at LAN B rings but user is unable to answer it. When user picks up, he can hear nothing. User can see that incoming call is coming and the phone rings but LAN B phone status is all the time "registering"......though it rings!?!
And also when user at LAN B picks up, he can't hear dial tone. So calling from LAN B phone -> to LAN A does not work.
Is there some configuration missing or why LAN B phone stays all the time registering status....though CME tells that this phone has been registered?!?
I have tried another 7942G phones but this same problem still occur. Thanks for help!
Please share your entire CME config.
Carlo
Please rate all helpful posts "The more you help the more you learn"
nirmalissac
So Signalling from CME ----- Phone is working
But RTP  Phone ---- Phone doesnt work
This should be a packet routing issue between the two vlans. Verify if both the subnets are pingable to each other. Check inter-vlan routing configurations. Basicalll, ping from both the subnets to the other phone subnet and see if it is pinging.
source ping from CME router interface -> to LAN B 7942G phone works OK!
I try to share my CME config later today.
Here is my CME current configuration:
Building configuration...
Current configuration : 7571 bytes
! No configuration change since last restart
version 15.1
hostname XXXXXXXXXXXX
boot-start-marker
boot-end-marker
logging buffered 51200 warnings
enable secret XXXXXXXXXXXXXXXXXXXXXXXX
no aaa new-model
no ipv6 cef
ip source-route
ip cef
ip dhcp excluded-address XXXXXXXXXXXXX
ip dhcp pool voice
network XXXXXXXXXXXXXXXX
option 150 ip XXXXXXXXXXXX
default-router XXXXXXXXXXXXXX
ip domain name yourdomain.com
crypto pki trustpoint TP-self-signed-4251620290
enrollment selfsigned
subject-name cn=IOS-Self-Signed-Certificate-4251620290
revocation-check none
rsakeypair TP-self-signed-4251620290
crypto pki certificate chain TP-self-signed-4251620290
certificate self-signed 01
  3082022B 30820194 A0030201 02020101 300D0609 2A864886 F70D0101 05050030
  31312F30 2D060355 04031326 494F532D 53656C66 2D536967 6E65642D 43657274
  69666963 6174652D 34323531 36323032 3930301E 170D3133 30313232 32323034
  31315A17 0D323030 31303130 30303030 305A3031 312F302D 06035504 03132649
  4F532D53 656C662D 5369676E 65642D43 65727469 66696361 74652D34 32353136
  32303239 3030819F 300D0609 2A864886 F70D0101 01050003 818D0030 81890281
  8100CA65 5E3DE099 ADB2DC57 B7DF90AD C5AD9885 3334D1A0 F098EB65 26EAE24A
  928F67A8 DD611244 FF49AFCE 4C5B340A C694E3D5 A104EF07 FB68F376 312CF219
  60C8C6BB 086DF76C D3948981 F08A3280 03A52255 B5D8463F 6972754F 3EA212A6
  EE3A21B3 726935E2 7FB3F1DA 6FBF1AF7 FFB10EB4 01C6C814 C22281AD D3F04AA6
  80590203 010001A3 53305130 0F060355 1D130101 FF040530 030101FF 301F0603
  551D2304 18301680 141946A0 CCFDEC6F 89074702 538363B5 31FD7A43 8A301D06
  03551D0E 04160414 1946A0CC FDEC6F89 07470253 8363B531 FD7A438A 300D0609
  2A864886 F70D0101 05050003 8181009B E2AD8E64 B2EE1713 DD8F88EC D6EC654B
  0E6513E2 F559DF9A D6888299 ED816CD8 3AD3DAB1 673FA076 FAE6BE39 6D90C856
  C6DE445F C10E6FF9 69953E8B BC89DB2C 5DB00445 82216DA7 152F64E9 AE724820
  C16B0AE5 9A286763 96E6F055 7AC60FA7 D32EC9BE 7003CCC9 E59FE762 46D7ECD3
  001DEEEB 048090A4 85E19BCE 73D2B8
        quit
voice-card 0
voice service voip
allow-connections sip to sip
fax protocol t38 version 0 ls-redundancy 0 hs-redundancy 0 fallback none
sip
  registrar server expires max 3600 min 120
voice register global
mode cme
source-address XXXXXXXXXXX port 5060
bandwidth video tias-modifier 512000 negotiate end-to-end
max-dn 200
max-pool 42
load 7942 SIP42.9-2-1S
timezone 26
time-format 24
date-format Y-M-D
tftp-path flash:
create profile sync 0393300046274344
ntp-server XXXXXXXXXXXXXXXXX mode directedbroadcast
voice register dn  1
number 1001
name XXXXXXXXXXXXXXXX
label 1001
mwi
voice register dn  2
number 1002
label 1002
mwi
voice register pool  1
id mac xxxx.xxxx.xxxx
type 7942
number 1 dn 1
presence call-list
dtmf-relay rtp-nte
codec g711ulaw
no vad
voice register pool  2
type 7942
number 1 dn 2
presence call-list
dtmf-relay rtp-nte
codec g711ulaw
no vad
license feature snasw
license udi pid CISCO2901/K9 sn xxxxxxxx
license accept end user agreement
license boot module c2900 technology-package securityk9
license boot module c2900 technology-package uck9
license boot module c2900 technology-package datak9
hw-module pvdm 0/0
redundancy
interface Loopback0
ip address XXXXXXXXXXXXXXXXXXXXX
interface Embedded-Service-Engine0/0
no ip address
shutdown
interface GigabitEthernet0/0
description XXXXXXXXXXXXXXX
duplex auto
speed auto
interface GigabitEthernet0/1
duplex auto
speed auto
ip forward-protocol nd
ip http server
ip http authentication local
ip http secure-server
ip http timeout-policy idle 60 life 86400 requests 10000
ip route XXXXXXXXXXXXXXXXXXXXXX
arp XXXXXXXXXXXXXXXXXXXXXX ARPA
tftp-server flash:apps42.9-2-1TH1-13.sbn
tftp-server flash:cnu42.9-2-1TH1-13.sbn
tftp-server flash:cvm42sip.9-2-1TH1-13.sbn
tftp-server flash:dsp42.9-2-1TH1-13.sbn
tftp-server flash:jar42sip.9-2-1TH1-13.sbn
tftp-server flash:SIP42.9-2-1S.loads
tftp-server flash:term42.default.loads
tftp-server flash:term62.default.loads
control-plane
mgcp profile default
gatekeeper
shutdown
telephony-service
max-ephones 10
max-dn 10
ip source-address XXXXXXXXXXXX port 2000
auto assign 1 to 10 type 7942
max-conferences 8 gain -6
transfer-system full-consult
create cnf-files version-stamp 7960 Apr 10 2013 04:53:36
banner exec ^C
% Password expiration warning.
Cisco Configuration Professional (Cisco CP) is installed on this device
and it provides the default username "cisco" for  one-time use. If you have
already used the username "cisco" to login to the router and your IOS image
supports the "one-time" user option, then this username has already expired.
You will not be able to login to the router with this username after you exit
this session.
It is strongly suggested that you create a new username with a privilege level
of 15 using the following command.
username privilege 15 secret 0
Replace and with the username and password you want to
use.
^C
banner login ^C
Cisco Configuration Professional (Cisco CP) is installed on this device.
This feature requires the one-time use of the username "cisco" with the
password "cisco". These default credentials have a privilege level of 15.
YOU MUST USE CISCO CP or the CISCO IOS CLI TO CHANGE THESE  PUBLICLY-KNOWN
CREDENTIALS
Here are the Cisco IOS commands.
no username cisco
to use.
IF YOU DO NOT CHANGE THE PUBLICLY-KNOWN CREDENTIALS, YOU WILL NOT BE ABLE
TO LOG INTO THE DEVICE AGAIN AFTER YOU HAVE LOGGED OFF.
For more information about Cisco CP please follow the instructions in the
QUICK START GUIDE for your router or go to http://www.cisco.com/go/ciscocp
^C
line con 0
password XXXXXXXXXXXXXXXXXXXXX
login
line aux 0
line 2
no activation-character
no exec
transport preferred none
transport input all
transport output pad telnet rlogin lapb-ta mop udptn v120 ssh
stopbits 1
line vty 0 4
privilege level 15
login
transport input telnet ssh
line vty 5 15
access-class 23 in
privilege level 15
login local
scheduler allocate 20000 1000
ntp master
ntp server XXXXXXXXXXXXXX
end
