change speed dial on 7975 with 7914
jorismaes
We use a cisco phone type 7975 with an expantion monudule 7914.
I would like to change and add some speed-dial buttons but can't find how to.
Can somebody tell me how to do this?
15 Replies 15
Hi Joris.
Did you configure a new Phone Button template for 7975 necessary to add speed dials with 7914 module?
Please use this doc as reference.
http://www.cisco.com/en/US/docs/voice_ip_comm/cucm/admin/8_6_1/ccmsys/a08ipph.html#wpmkr1262133
Carlo
Please rate all helpful posts "The more you help the more you learn"
Thanks for the fast answer, but who rote this "tutorial"???
Damn, could it be more text to just add a number and name to a button?
Do I really have to struggle trough all this text?
Just a cisco Engineer wrote it and if people like me know to configure a 7914 module is because we've read also that doc
Anyway, follow these easy steps:
1) go to Device --> Device Settings ---> Phone Button Template
2) Click ADD
3) From the drop down list select Standard 7975Sccp
4) Click Copy
5) Name the new template as eg. 7975-Sccp-7914
6) Click Save.
7) modify line from 7 through 20 as Speed dial
8) click save
9) Go to 7975 phone configuration
10) in phone button template select the created template
...and you're done.
Carlo
Please rate helpful posts
OK, "Device": where?
obvious... on the CUCM administration page.
Or, ask to a qualified engineer to help you in this task.
Carlo
  1. We bought a complete cisco installation for about 30 users
  2. the company who sells this can't work with it them selves, they needed 2 hours and a lot of phone call's to change 2 names. (hour rate: €95!) surprised I want to change basic things like that myself?
  3. a phone, that's to ring, not a science
  4. this phone can do a lot less than a smartphone, but is 10 times more complicated to modify.
  5. I am not a noob in informatics still, adding a speed dial is much to complicated for me
  6. all this "help"-pages are in englisch, if your native language isn't Englisch (like I do), it is extra complicated to understand
  7. I have receive a series of log-in's and passwords, but no CUCM URL
  8. last: we should have bought an alcatel phone...
    Joris,
    The CCM Admin page would be as follows https://0.0.0.0/ccmadmin (replace the 0.0.0.0 with the IP address of your Call Manager). In regards to changing the speed dial when you log into the CCM Admin page go to Device>Phone and do a search either via the directory number or the name (MACaddress of the phone starting with SEP). When you open the phone page either on the right side of the page you will see the configured buttons with the speed dial number or you can go to the top right of the page and under Related Links drop downselect Add\Update Speed Dials from the list.
    Hope this helps.
    Yosh
    HTH Regards, Yosh
    Joris,
    now that I've a clearer vision, of your situation, I can tell you that every settings of your IP Phone, are configured through The callmanager administration pages except some presonal settings (eg. ringtone or background).
    Another option to  modify your speed dial (add/delete/change) is to ask to the company wich istalled the system, to provide you the access to presonal user page, so you can modify some settings of your ip phones.
    Hope this would help.
    Carlo
    I tried all the given IP-numbers, no result.
    I give up.
    thanks anyway.
    Hi Joris.
    To se the CUCM IP address, on your phone use the settigns button (the one with a check in the middle) select network configuration than scroll down to Server TFTP1 and that's the ip address of the CUCM.
    Carlo
    Thuesday a support engineer of the company where we bougt the phones was here to change the names.
    I asked him for a web interface to change some settings. He said that doesn't exists, he did the changes with putty.exe
    I looked for the IP address on my phone, that was the number I tested before, unfortunately without result.
    Joris,
    My apologies we should've asked what version of CUCM you are using. You have CUCM Express which ia ran on a router. Did the installers leave you any credentials? The way you would log into CUCME would be to use putty (or any ssh software) and select ssh as the protocol and put the IP Address of your CUCME. Once it connects it will prompt you for the username and password. Below is a link for CUCME Administraition Guide which will help you.
    http://www.cisco.com/en/US/docs/voice_ip_comm/cucme/admin/configuration/guide/cmeadm.html
    Yosh
    HTH Regards, Yosh
    Hi Joris.
    Please tell the engineer to enable on CME (the phone System) the dn webedit function so that you and your collegues will be able to personalize some settings  of  your IP Phones by yourselves.
    The link that Yosh secified could help engineer to configure this function.
    Regards.
    Carlo
    jorismaes
    I asked this to our support.
    They told me they can do this, but if they do this they need to reconfiggure the complete installation.
    Is this correct?
