Hi Guys,
I have 3 IP phones 7960 and one is registered with router 2811 and two not registered!
The one is registered i added load 7960-7940 P00303010200.loads under telephony-services and is OK
but the other two is load 7960-7940 P00308000900.loads and load 7960-7940 P00308000500.loads but always getting a message debugging:
TFTP: Looking for term42.default.loads
Mar 21 19:33:57.602: TFTP: Looking for CTLSEP0015F9ED383D.tlv
Mar 21 19:33:57.666: TFTP: Looking for SEP0015F9ED383D.cnf.xml
Mar 21 19:33:58.318: TFTP: Opened system:/its/XMLDefault7960.cnf.xml, fd 0, size 787 for process 239
Mar 21 19:33:58.322: TFTP: Finished system:/its/XMLDefault7960.cnf.xml, time 00:00:00 for process 239
Mar 21 19:33:59.282: TFTP: Looking for term42.default.loads
Mar 21 19:37:16.386: TFTP: Looking for CTLSEP00215553D8FB.tlv
Mar 21 19:37:16.406: TFTP: Looking for SEP00215553D8FB.cnf.xml
Mar 21 19:37:16.414: TFTP: Opened system:/its/XMLDefault7960.cnf.xml, fd 0, size 793 for process 239
Mar 21 19:37:16.418: TFTP: Finished system:/its/XMLDefault7960.cnf.xml, time 00:00:00 for process 239
Mar 21 19:37:16.454: TFTP: Looking for P00308000500.loads
Mar 21 19:37:16.482: TFTP: Looking for P00308000500.sbn
Router 2811 :
Cisco IOS Software, 2800 Software (C2800NM-ADVIPSERVICESK9-M), Version 12.4(18), RELEASE SOFTWARE (fc1)
Copyright (c) 1986-2007 by Cisco Systems, Inc.
Compiled Fri 30-Nov-07 16:36 by prod_rel_team
ROM: System Bootstrap, Version 12.4(13r)T, RELEASE SOFTWARE (fc1)
ROUTER-B uptime is 5 hours, 18 minutes
System restarted at 14:20:03 UTC Thu Mar 21 2019
System image file is "flash:c2800nm-advipservicesk9-mz.124-18.bin"
how can I solve this issue, please?
Thanks for all
