7960 IP phone CFwdALL from voicemail
melwoods
Is there a way to set call CFwdALL on your 7960 IP phone by dialing into your extension from another phone?
The following I know to be true:
1) On the ip phone, you can select the softkey 'CFwdALL'
-or-
2) You can also go the CCM User page, and login as a user and set it there.
The scenario I have is this:
An end user is away from the office and forgot to forward their phone.  The end user wants to be able to dial their work extension, thus putting them into their voice mailbox, and from there be able to set their phone to CFwdALL.  Is this possible?  I haven't been able to find anything on the web stating that it is.
Thanks all.
Melvin
Jaime Valencia
No, it's not possible, you would need to develop an app in something like UCCX/UCCE to get the info, and then somehow push it to CUCM's DB
java
if this helps, please rate
www.cisco.com/go/pdihelpdesk
java
