7961 and 7941 phones unable to register to ccme router
ayen
I ran into an issue where 7961 and 7941 phones are unable to register to ccme router 2811, looks like a .tlv file that begins with CTLSEP is missing at the cme router.
Tried to factory reset the phone, installed various IOS images on the 2811 but still not working
If any one has dealt with this issue previously, please let me know how you fixed it. Thanks
2 Accepted Solutions
Aaron Harrison
Don't worry about the CTLSEP file; it's basically the phone trying to download a certificate trust list in case the CME/CUCM it is trying to register to is configured in 'secure' mode:
Secure and Nonsecure Configuration
The Cisco IP Phone 7960 and 7940 platform supports configuration-file authentication, certificate installation, and device authentication with the call control unit. By default, the phone is nonsecure until the phone detects that it needs to take additional steps to configure itself in secure mode. The initial step in this determination is through a CTLSEP MAC file request upon bootup (for example, CTLSEP003094C25D2E.tlv). The CTLSEP MAC file is a certificate trust list, which if populated, contains information about the servers to which the phone is attempting to connect and whether the server connection will be secure or nonsecure.
The CTLSEP MAC file is the first file requested in the universal application loader, followed by the additional six configuration files in the hunt algorithm defined in the "Universal Application Loader" section. If the CTLSEP MAC file is present, the phone proceeds with additional security actions regarding phone and server communication; if the CTLSEP MAC file is not present or is empty, the phone proceeds in nonsecure mode with the hunt algorithm.
Perhaps post up your CME config.
Have you configured 'create cnf-files' under telephone-service?
Are you debugging TFTP from the router, or from the phone status messages screen?
Aaron
Aaron Please remember to rate helpful posts to identify useful responses, and mark 'Answered' if appropriate!
get into config t
Unter telephony service replace that ip address with the loopback address.
ip source-address port 2000
exit
Create cnf-files
reset your ephone
and see if it registers.
If this helps, please rate.
thanks.
Aaron Harrison
Aaron
Hey
Problem is still there, right now there are two phones 7960 and 7961, 7960 is fine, only 7961, if I remember correctly, 7941 also had this issue.
Yes, ‘create cnf-files’ has been configured under telephony-service.  The debug tftp event output may indicate that CTLSEP….tlv could be the issue.
*Oct 16 02:09:17.425: TFTP: Looking for CTLSEP000AB830C3A6.tlv
*Oct 16 02:09:17.545: TFTP: Looking for SEP000AB8A8C3A6.cnf.xml
*Oct 16 02:09:17.549: TFTP: Opened flash:/its/vrf1/SEP000AB830C3A6.cnf.xml, fd 7, size 1278 for process 232
*Oct 16 02:09:17.557: TFTP: Finished flash:/its/vrf1/SEP000AB830C3A6.cnf.xml, time 00:00:00 for process 232
Phone status message also has similar messages
1:01:14a File Not Found : CTLFile.tlv
1:01:14a No CTL installed
1:01:14a SEP000AB830C3A6.cnf.xml
1:04:08a File Not Found : CTLFile.tlv
1:04:09a No CTL installed
1:04:09a SEP000AB830C3A6.cnf.xml
br2-rtr#show ephone
ephone-1[0] Mac:0007.8551.EC18 TCP socket:[1] activeLine:0 REGISTERED in SCCP ver 11/9
mediaActive:0 offhook:0 ringing:0 reset:0 reset_sent:0 paging 0 debug:0 caps:8
IP:10.10.202.55 50570 Telecaster 7960  keepalive 43 max_line 6 available_line 6
button 1: dn 1  number 3001 CH1   IDLE
Preferred Codec: g711ulaw
ephone-2[1] Mac:000A.B830.C3A6 TCP socket:[-1] activeLine:0 UNREGISTERED
mediaActive:0 offhook:0 ringing:0 reset:0 reset_sent:0 paging 0 debug:0 caps:0
IP:0.0.0.0 0 Unknown 0  keepalive 0 max_line 0 available_line 0
br2-rtr#show ephone registered
version 12.4
hostname br2-rtr
boot-start-marker
boot system flash flash:c2800nm-adventerprisek9-mz.124-22.T4.bin
boot-end-marker
card type t1 0 0
card type e1 0 1
logging message-counter syslog
no aaa new-model
clock timezone CET 1
clock summer-time CET recurring
no network-clock-participate wic 0
network-clock-participate wic 1
dot11 syslog
ip source-route
ip cef
no ip dhcp use vrf connected
ip dhcp excluded-address 10.10.202.1 10.10.202.49
ip dhcp excluded-address 10.10.202.70 10.10.202.254
ip dhcp pool CME
   network 10.10.202.0 255.255.255.0
   option 150 ip 10.10.110.3
   default-router 10.10.202.1
no ip domain lookup
no ipv6 cef
voice-card 0
vtp mode client
archive
log config
  hidekeys
! controller T1 0/0/0
cablelength long 0db
channel-group 0 timeslots 1-24
controller T1 0/0/1
controller E1 0/1/0
interface Loopback0
ip address 10.10.110.3 255.255.255.255
ip ospf network point-to-point
interface FastEthernet0/0
no ip address
duplex auto
speed auto
interface FastEthernet0/1
no ip address
duplex auto
speed auto
interface FastEthernet0/3/0
switchport mode trunk
interface FastEthernet0/3/1
interface FastEthernet0/3/2
interface FastEthernet0/3/3
interface Serial0/0/0:0
no ip address
encapsulation frame-relay IETF
no fair-queue
frame-relay lmi-type ansi
interface Serial0/0/0:0.1 point-to-point
ip address 10.10.112.2 255.255.255.0
ip ospf mtu-ignore
snmp trap link-status
frame-relay interface-dlci 102
interface Service-Engine1/0
no ip address
shutdown
interface Vlan1
no ip address
interface Vlan200
ip address 10.10.102.1 255.255.255.0
interface Vlan400
ip address 10.10.202.1 255.255.255.0
router ospf 1
router-id 10.10.202.1
log-adjacency-changes
network 10.10.0.0 0.0.255.255 area 0
ip forward-protocol nd
ip http server
no ip http secure-server
tftp-server flash:P00308000900.bin alias P00308000900.bin
tftp-server flash:P00308000900.loads alias P00308000900.loads
tftp-server flash:P00308000900.sb2 alias P00308000900.sb2
tftp-server flash:P00308000900.sbn alias P00308000900.sbn
tftp-server flash:apps41.8-3-2-27.sbn alias apps41.8-3-2-27.sbn
tftp-server flash:cnu41.8-3-2-27.sbn alias cnu41.8-3-2-27.sbn
tftp-server flash:cvm41sccp.8-3-2-27.sbn alias cvm41sccp.8-3-2-27.sbn
tftp-server flash:dsp41.8-3-2-27.sbn alias dsp41.8-3-2-27.sbn
tftp-server flash:jar41sccp.8-3-2-27.sbn alias jar41sccp.8-3-2-27.sbn
tftp-server flash:SCCP41.8-3-3S.loads alias SCCP41.8-3-3S.loads
tftp-server flash:term41.default.loads alias term41.default.loads
tftp-server flash:term61.default.loads alias term61.default.loads
tftp-server flash:MK-SCCP.JAR alias English_United_States/mk-sccp.jar
tftp-server flash:G3-TONES.XML alias United_States/g3-tones.xml
control-plane
ccm-manager fax protocol cisco
gateway
timer receive-rtp 1200
sip-ua
telephony-service
no auto-reg-ephone
max-ephones 3
max-dn 3
ip source-address 10.10.100.3 port 2000
system message BR2 CME
cnf-file location flash:
cnf-file perphone
load 7960-7940 P00308000900
load 7961 SCCP41.8-3-3S
date-format dd-mm-yy
max-conferences 8 gain -6
transfer-system full-consult
create cnf-files version-stamp 7960 Oct 15 2010 06:55:06
ephone-dn  1
number 3001
description 3214-3001
ephone-dn  2
number 3002
description 3214-3002
ephone-dn  3
number 3003
description 3214-3003
ephone  1
device-security-mode none
mac-address 0007.8551.EC18
max-calls-per-button 5
busy-trigger-per-button 3
type 7960
button  1:1
ephone  2
mac-address 000A.B830.C3A6
type 7961
button  1:2
line con 0
line aux 0
line 66
no activation-character
no exec
transport preferred none
transport input all
transport output pad telnet rlogin lapb-ta mop udptn v120 ssh
line vty 0 4
privilege level 15
password cisco
login
transport input all
line vty 5 15
privilege level 15
password cisco
login
scheduler allocate 20000 1000
ntp source Vlan400
ntp server 10.10.100.2
end
Searched for other postings, this post has a similar issue. https://supportforums.cisco.com/message/337619#337619.  my temporary work around is to use this 7961 to register to call manager and use another 7960 phone for br2.  But I really want to find an answer.  Thanks.
get into config t
exit
Create cnf-files
reset your ephone
thanks.
