IP Telephony and Phones
watch here Journey banner_2
Labels
Hi,I am facing issue with the call forwarding . Calls forwarded to national PSTN or mobile numbers disconnect after 10-15 seconds if unanswered by the destination. Can anybody know if there is any timer configuration in call manager , where we can se...
Hello All,We have Cisco 1861, I have done Voip deployment on it, i attached my running-configuration & Flash details, can anyone look it, help me or please let me know if  I am wrong anywhere in config because I'm Unable to open Cisco Unified Communi...
help requiredi have setup a small home network to practice voip, the lab consists ofone 3550 switch a cisco 2621xm router with a aim-cue voicemail module installed and running ios c2600-ipvoicek9-mz.124-11.XJ4.bin a cisco 2621 acting as a ntp server ...
Since upgrading to CER 7.1.1.20000-1 it is no longer identifying phones after running switch-port/phone update. I see all my switches and ports are in the correct ERL. SNMP strings are correct for Call Manager and CER, i can ping Call Manager from CE...
jszapipes by Level 1
  • 3381 Views
  • 6 replies
Hi All,I would like to ask if somebody how is the best solution to monitor a SIP Trunk?Because we are having now a SME Cluster and to this cluster we will connect a CUCM Cluster but currently I have no idea how to monitor it.Is it possible that the C...
Top Solution Authors
