07-15-2011 02:06 PM - edited 03-16-2019 05:58 AM
I have a 7961 that I did a factory reset command on, I see it reboot and show a screen with upgrading and term61.default
The phone displays that for a few seconds and then reboots and after 30 sec or so displays the same thing.
Any ideas on how to fix this?
Solved! Go to Solution.
07-15-2011 02:10 PM
Are you trying to register it to the CUCM or CUCME? Check whether the phone has obtained an IP address and TFTP server address. Also make sure the CUCM/CUCME has the firmware files that the phone is requesting for.
Nitesh
PS:Pl rate helpful posts
07-15-2011 02:10 PM
Nitesh
