09-15-2016 07:22 AM - edited 03-17-2019 08:05 AM
Hello everybody,
I’m facing an issue that i can’t resolve and understand exactly where is the problem.
It happens only with Cisco IP Phone 7962.
The issue is that during some registration phase, the phone freez (up to 20 minutes).
1. When i analyze IP Phone logs (IHM/ Device Logs) I have:
On DebugDisplay:
Invalid SCCP message! : Invalid length = 0 - close connection and alarm in future
On logxxx: (see attached file)
2. When i analyze SCCP paquets (between the Phone and the CME) I have found that on XMLAlarmMessage message (sent before register message), I can check the last sccp message received before the Freez and It indicate “SoftKeySetResMessage”
But for me, this is sent normally (with TCP fragmentation) and I can’t found any problem on this message.
Can you help me to fix out this issue ? Do you have any idea or other logs to check? …
Thank you very much for your help.
09-15-2016 07:34 AM
What are the CME and IP phone firmware versions? Did the issue start recently? Can you try upgrading the firmware in the 7962's and see if that helps.
Manish
09-15-2016 07:54 AM
the firmwares tested are:
IPPhone: SCCP42.9-3-1SR3-1S
CME(2951): - SPA.154-2.T1
- SPA.156-2.T
Now, i'm trying to put the new versions :
IPPhone: SCCP42.9-4-2SR2-2S
CME(2951): SPA.156-2.T1
i will give you a feedback when i will finish the test
09-21-2016 04:13 AM
It works good with the new IP Phone firmware (SCCP42.9-4-2SR2-2S).
It seems to be a bug on (SCCP42.9-3-1SR3-1S)
BR,
09-21-2016 04:16 AM
Thanks for updating the post, yes it looks to be a bug on the old firmware.
Manish
