ā05-26-2011 06:10 AM - edited ā03-16-2019 05:09 AM
I have a 7962G with 7915 expansion module. I have a phone button template of 5 Lines/1 Intercom/ 12 BLF. None of the BLF buttons will light when the designated dn is on the phone. The button will work as a speed dial just fine.
Suggestions/thoughts??
Solved! Go to Solution.
ā05-26-2011 06:32 AM
Check that your subscribe CSS is configured to reach the partitions that the lines you want to monitor are in.
ā05-26-2011 07:04 AM
Thanks Joe, that did correct the problem. After reading the description of Subscriber CSS it makes sense.
Again, much appreciated.
