06-27-2019 09:00 AM
Hello all,
I am running cucm vs 12.0 with multiple servers in the cluster...
We are running into an issue with one of our sites using the 7965 phones, each phone has 2 lines configured on it. When the phones are registered to one server, the phones display both lines but the moment i update the CM group to have them register to another server, the phones only show 1 line. I have factory reset the phones multiple times but it did not resolve the issue...I am lost as to the source of the problem.
Any input or recommendation would be much appreciated
BTW, all the servers have the same service running on them
Stella
06-27-2019 10:46 AM
Assuming the two CUCM servers are in the same cluster? Have you checked db replication status? See steps below.
Brandon
06-27-2019 11:08 AM
06-28-2019 09:33 AM
Yes, both nodes are on the same cluster. Db replication is good, i have a 2 for the status
Also, other phone models when registered to this server would display both lines but for some reason, the 7965 phone doesn't and this happens only when it is registered to the server. If i change it to register to another node, both line appearances are displayed
Any additional insight would be appreciated
Stella
06-29-2019 06:48 AM
Did you do utils dbreplication status and then utils dbreplication runtimestate? If not, do utils dbreplication runtimestate again and look at the date. If it is not recent, run utils dbreplication status which will actively check the status of all tables. Then run utils dbreplication runtimestate again to see if the replication still shows good.
Maren
07-01-2019 05:01 AM
Hi Maren,
Good Morning! Thanks for responding, It is so good to hear from you. I was in your advance class last month...:)
So when I run the utils dbreplication runtimestate command, it only gives me the date the command was ran. see below
"Cluster Replication State: Replication status command started at: 2019-07-01-07-35"
I also ran dbreplication status and then utils dbreplication runtimestate and the status still shows good.
Stella
07-01-2019 05:30 AM
Well hideeho Stella! You were in the class with the group based in Winchester and I absolutely remember you. It's always fun to run into one of my students here!
If you've verified replication with utils dbreplication status/runtimestate and it's showing good (which makes me very surprised) then I'm not at all sure what is going on.
So this is all of the 7965's at one site, but only the 7965's at that site? And you have 7965's at other sites that are behaving normally? Interesting.
Here is what I would try next, in order:
Keep me/us posted.
Maren
