7965G IP Phone not going into Voice mail after 4 rings.
Val Constable
Hello This Val , can someone tell me how to fix this problem.
ISSUE
Cisco IP Phone 7965g: The Call manager Unity does have the correct setting but the phone still not (After 4 Rings) going to voicemail.
Val.
Rob Huffman
Hi Val,
On the DN config page in CUCM can you please check the Forward No Answer
CSS (calling search space) and the  No Answer Ring Duration timer;
Call Forward and Call Pickup Settings
Voice Mail Destination Calling Search Space
Calling Search Space Activation Policy
or
Secondary Calling Search Space for Forward All
or
or
or
or
or
or
or
or
or
Cheers!
Rob
"I don't know how, I don't know when
But you and I will meet again "
- Tom Petty
Jaime Valencia
Do you have the right VM profile and CFNA settings??
Is this the only DN that has that behavior?
java
if this helps, please rate
www.cisco.com/go/pdihelpdesk
java
Rob Huffman
Hi Val,
or
or
or
or
or
or
or
or
or
or
Cheers!
Rob
- Tom Petty
This worked out great, I edited the DN Config page and just checked the correct option.
Val.....
Hi Rob what do you know about the following.
My TFTP Server cannot communicate to my Cisco 6500 E Switch which is the DHCP SERVER.
How can I fix this?????
Val...
