07-01-2013 11:24 AM - edited 03-16-2019 06:10 PM
Hello This Val , can someone tell me how to fix this problem.
ISSUE
Cisco IP Phone 7965g: The Call manager Unity does have the correct setting but the phone still not (After 4 Rings) going to voicemail.
Val.
Solved! Go to Solution.
07-01-2013 11:35 AM
Hi Val,
On the DN config page in CUCM can you please check the Forward No Answer
CSS (calling search space) and the No Answer Ring Duration timer;
Cheers!
Rob
"I don't know how, I don't know when
But you and I will meet again "
- Tom Petty
07-01-2013 11:31 AM
Do you have the right VM profile and CFNA settings??
Is this the only DN that has that behavior?
java
if this helps, please rate
www.cisco.com/go/pdihelpdesk
07-01-2013 11:35 AM
Hi Val,
Cheers!
Rob
- Tom Petty
07-01-2013 12:07 PM
This worked out great, I edited the DN Config page and just checked the correct option.
Val.....
07-01-2013 12:10 PM
Hi Rob what do you know about the following.
My TFTP Server cannot communicate to my Cisco 6500 E Switch which is the DHCP SERVER.
How can I fix this?????
Val...
