7975 firmware for call manager express
pranavluhar
i would like to add 7975 phone to call manager express.
where do I get the firmware for 7975 for cme?
i tried from software.cisco.com but it's for call manager only.
6 Replies 6
Charles Hill
I believe the software you are looking for is at the link below.
https://software.cisco.com/download/release.html?mdfid=281346597&softwareid=282074289&release=9.4%282%29&relind=AVAILABLE&rellifecycle=&reltype=latest
7975 SCCP IP Phone firmware files only - Compatible UCM versions 4.3.2, 5.1.3, 6.0.1, 6.1.3, 6.1.4, 7.0.2, 7.1.2 and above
cmterm-7975-sccp.8-5-4.zip
This is for ucm , I am looking for call manager express.
Hi pranavluhar,
 check this link cme-153-3Mv2.rar (in 10.0 option).There is a 7975 version for CUCME.
Hope this helps.
 I was referencing the link below, it looks like they are the correct files for CME.
The link also gives the steps to install the files.
https://supportforums.cisco.com/discussion/10558871/upgrading-7975g-firmware
If you open the zip file, the files look like the same files referenced in the posting.  Different firmware version, though, but same file ext.
7975G it's the same 7975
j.huizinga
Level 6
Level 6
download the zip files
