Cisco SBC Signal and media port range
We are configuring Cisco 44XX series SBC/CUBE for MS Teams direct routing configuration with NAT configuration. We are following below doc but it does not mention about default SBC port range for configuration. What is default media port range on Cisco SBC/CUBE ?
https://www.cisco.com/c/dam/en/us/solutions/collateral/enterprise/interoperability-portal/deploying-a-multi-tenant-direct-routing.pdf
Could you please guide us that what will be signal and media port range on Cisco SBC for MS Teams direct routing for NAT configuration ?
3. Ports that will requested on the sbc from the Microsoft side
4. Ports that will requested on the Microsoft Microsoft side from the sbc end
Traffic From To Source port Destination port
SIP/TLS SIP Proxy SBC 1024 – 65535 Defined on the SBC (For Office 365 GCC High/DoD only port 5061 must be used)
SIP/TLS SBC SIP Proxy Defined on the SBC 5061
UDP/SRTP Media Processor SBC 3478-3481 and 49152 – 53247 Defined on the SBC
UDP/SRTP SBC Media Processor Defined on the SBC 3478-3481 and 49152 – 53247
Can we use TCP 5061 for SIP signal and media port range 16384-32767 on Cisco SBC/CUBE ?
Vaijanath Sonvane
Hi @madhav.kumar.bhardwaj12.,
Most Cisco documentation specifies that RTP & RTCP traffic will use a dynamically chosen port number in the range 16384 to 32767, with RTP using an even port number & RTCP using the subsequent odd numbered port.
However as of IOS XE 3.10.2 the 4000 series routers actually use the range 8000 to 48200 by default. You can use below configuration on CUBE router to limit the range of RTP ports:
voice service voip
  rtp-port range 16384 32766
Recently I did the similar project to integrate Cisco 8000 Router with MS Teams Direct Routing and prepared an attached port document. Hope this is helpful to you.
The updated information regarding signaling and media ports is available on Microsoft site:
https://learn.microsoft.com/en-us/microsoftteams/direct-routing-plan
Please rate helpful posts and if applicable mark "Accept as a Solution".
Thanks, Vaijanath S.
Vaijanath Sonvane
voice service voip
Thanks @Vaijanath Sonvane for quick response. Shared doc is really helpful. I have additional queries -
1. For 8XXX service SBC, can i use the same media port range UDP 16384 to 32766 ?
16384 32766
 2. We are configuring SBC without Media bypass option which means we are using NAT on SDWAN with internal IP address on SBC which will be mapped to public IP address of SDWAN. To create DNS A records in public DNS Server for SBC FQDN mapping to the public IP Address - I assume, we need to use SDWAN Public NAT IP address for DNS A record for SBC FQDN. Correct ?
3. What are best security policies or configuration on Cisco CUBE/SBC which we can implement to protect from Internet access such as ACL configuration to allow only MS Teams traffic etc ?
Vaijanath Sonvane
Hi @madhav.kumar.bhardwaj12,
1. Yes, you can use this port range.
2. This is how I have deployed SBCs for customer with 1:1 NAT. The public DNS record must have SBC FQDN with NATed public IP Address.
3. As the SBC router is behind the firewall, we allowed only the IP Address ranges and ports mentioned in the document on firewall.
