7985 unsupported protocole for background image
hani_altaher
i make background images for 7985 Video(firmware of 7985 is 4.1.2) phone but when i select one of the listed image the error message indicating this image is not supported protocole. i check configuration as followin:
1. make image with 800x600 PNG file
2.put the prevouise image 80x600x16
3.edit List.xml file as
<ImageItemImage="TFTPPath:Desktops/800x600x16/logo7985.png"
URL="TFTPPath:Desktops/800x600x16/logo7985.png"/>
4.after that image is listed but whn i select it the error messege appear unsupported protocole.
thanx alot
Rob Huffman
Hi Hani,
Have a look at this good doc for the 7985;
http://www.cisco.com/application/pdf/en/us/guest/products/ps6564/c1693/ccmigration_09186a008069e1b0.pdf
It looks like the List.xml should look like this;
FTP:Desktops/800x600x16/logo7985.png"
URL="TFTP:Desktops/800x600x16/logo7985.png"/>
with a space between ImageItem and Image and with just TFTP rather than TFTPPath.
Hope this helps!
Rob
Please remember to rate helpful posts.....
Dear Rob
thank you vey much its working and everything is fine .
Kind Regards.
