8811 right button speed dial problem
ALI.TURSUN
I installed CUCM and ipphone 8811 , 7861 and 7811
I configured phone button template for 8881 ,7861 and 7811.
for example i can add 10 speed dial button for 8811 . But i can see only left button (5 SD) on the phone. i can not see righ button.
You can see CUCM and ip phone version .
How can i resolve this problem ?
CUCM System version: 11.5.1.10000-6
rootfs88xx.11-5-1-18
Boot load ID sb288xx.BE-01-019
Version sip88xx.11-5-1-18
Hardware revision V01
App Load ID rootfs78xx.11-5-1-18
Boot Load ID sboot78xx.11-5-1-18
Version sip78xx.11-5-1-18
Hardware Revision
33
Hardware Revision 35
4 Accepted Solutions
Chris Deren
Set the "Line Mode" setting on the device to "Enhanced Line Mode" which will allow you to use the 5 sessions buttons as line buttons instead.
Hi Chris,
Thanks for help. your recommanded is work.
But only work for 8811.
I can not see Enhanced Line Mode for 7861.
I tried 7861 and only 5 button is working but not work more button
How can i resolve for 7861 ?
Best regards
Ali
That feature is only available on 88XX models. Other models you are limited to the line buttons as they are only at this point.
Hi Chris,
Thanks for help
5 Replies 5
Chris Deren
Hi Chris,
Best regards
Ali
Hi Chris,
Thanks for help
rahmathalipnp
set line mode on enhanced line on device page to resolve this issue
